Re: Trans Question (what does the pivot shaft do?)
[Re: BDW]
#488099
10/04/09 04:23 PM
10/04/09 04:23 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The external RTV fix only works if the fluid level is drained to a level below the pin and the area thoroughly cleaned prior to application of the RTV. If the fluid level remains above the pin the fluid will continue to leak out as the RTV is curing and it won't bond.
[Re: BDW]
#488100
10/04/09 11:49 PM
10/04/09 11:49 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
This spot, thought it was called a pivot pin?
Are you sure it is the pin and not the tail shaft bolt above it? The bolt does not look stock, and I think the bolt hole os open in the case so it needs thread sealer on the bolt. Anyhow, as mentioned the pin seals to the case with an "O" ring on the pin, but if you pull it out the reverse band lever, and parts will fall out of place. You did not say what RTV you used? I would tru cleaning the old RTV out, clean the area with beake cleaner and try sealing it with the black MOPAR transmission RTV. The Mopar transmission RTV seems to work great! I had a crack in my filler tube where the "O"-ring sits, and I just smeared the black RTV around the tube and O-ring and plugged it back in, and no more leaks.
