i installed nozzles in a standard b1 intake for a friend, he was running an injectorator but i didn't take any pics. i just mounted the manifold in the bridgeport, drilled and tapped the intake for 1/8 NPT which is what the nozzles were. i'm pretty sure i installed them in the runners but as thick as the flanges are you could probably put them in the flange as well. it wasn't too difficult because of the flange angles you could mount it in the machine easy. i also did a indy manifold for another friend that iirc was a real pita. the b1 intake is pretty thick as shipped, heck if you're careful you could probably do it by hand.
