Source for a 1971 A-body Ignition switch? #487775
10/04/09 11:23 AM
10/04/09 11:23 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I need a couple new or NOS ignition switches & keys for 71 A-bodies, does anyone know if they are available? I'd prefer to give the business to a board member.
Thanks!
Re: Source for a 1971 A-body Ignition switch? [Re: ScottSmith_Harms] #487776
10/04/09 11:26 AM
10/04/09 11:26 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Local parts store?
Re: Source for a 1971 A-body Ignition switch? [Re: ScottSmith_Harms] #487777
10/04/09 11:27 AM
10/04/09 11:27 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
are you after the satin or chrome finish on the external tabs ?
I'll ck tomorrow on avail of any access to NOS
Re: Source for a 1971 A-body Ignition switch? [Re: gtx6970] #487778
10/04/09 11:29 AM
10/04/09 11:29 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
They aren't for my cars Bill so I don't know, I'll see if I can find out. Thanks guys!
*Parts stores have them? Never thought to ask (Duh!), figured they'd be obsolete by now
Re: Source for a 1971 A-body Ignition switch? [Re: ScottSmith_Harms] #487779
10/04/09 11:47 AM
10/04/09 11:47 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
AMPCO LS415C is pictured here....some other brands who made them back in the day;
US71L STANDARD
AL138K NIEHOFF
K6621 ECHLIN
3522LC FILKO
REPLACES MOPAR#2999444,3454264&265
Re: Source for a 1971 A-body Ignition switch? [Re: Joesixpack] #487780
10/04/09 05:52 PM
10/04/09 05:52 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Scott,
I just thought about this .
do you need the actual electrical portion of the switch or the chrome key tumbler portion
Re: Source for a 1971 A-body Ignition switch? [Re: gtx6970] #487781
10/04/09 06:29 PM
10/04/09 06:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
He has both switches complete, the inner workings have failed on both (the cars start after you turn the kry all the way, but only after you let OFF the key). He'd like to change out the whole deal but parts to fix them would be ok as well I guess.
Re: Source for a 1971 A-body Ignition switch? [Re: ScottSmith_Harms] #487782
10/04/09 06:32 PM
10/04/09 06:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure that's the problem? Has he checked the bulkhead plug for corrosion or burnt terminals?
Re: Source for a 1971 A-body Ignition switch? [Re: stumpy] #487783
10/04/09 07:24 PM
10/04/09 07:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, all of the wiring in both cars is brand new M&H stuff front to rear (except the steering column wiring) and the problem was there before changing it all out as well.
