What is needed to go from gas to Alky (carbed" #487693
10/04/09 10:02 AM
10/04/09 10:02 AM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
I like the idea of using the same fuel for both race cars, what is needed to switch to alky from race gas?
Diego
Re: What is needed to go from gas to Alky (carbed" [Re: Diego_Ted] #487694
10/04/09 11:15 AM
10/04/09 11:15 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Same as your alky car has. Just have to make sure everythings happy with alky
- Alky carb or injection
- Different fuel pump maybe, or just change the seals in your current if it can't take alky. Maybe a bigger pump however if your current one is marginal on gas
- Lines/fittings/seals, all have to be good with alky
- Regulator (alky happy)
- Fuel filter(s) (alky happy)
Fuel cell should probably be ok, but might want to check (yours has a sender in it IIRC).
The nitrous system is another whole deal though. For simplicity since you'd have to change out pricey items and also re-tune it I'd just use gas in the nitrous system and alky for the motor for now then maybe switch once you've sorted out the main fuel delivery system.
Re: What is needed to go from gas to Alky (carbed" [Re: Diego_Ted] #487695
10/04/09 11:20 AM
10/04/09 11:20 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
From the research I've been doing this is what I learned.
You need a good pump (alky motors are thirstier than gas), -10 or 5/8's lined prefered. Filter must be stainless not paper. A lean out valve is a good idea to help warm it up. Oh yeah, and the carb.
I haven't yet made the switch just been doing a lot of research.
Re: What is needed to go from gas to Alky (carbed" [Re: Diego_Ted] #487696
10/04/09 11:29 AM
10/04/09 11:29 AM
madison, ohio
modified1090 Offline
madison, ohio
i'm running E85 ethanol alcohol and i didn't have to change anything. a friend of mine retunned the carb. thats all. it was only a 30% increase in fuel consumption versus the methanol increase of almost double sometimes more.
Re: What is needed to go from gas to Alky (carbed" [Re: Diego_Ted] #487697
10/05/09 05:34 PM
10/05/09 05:34 PM
OH, USA
GORacing Offline
super street
GORacing  Offline
super street
OH, USA
If you do it right, and want the least amount of headaches down the road:
Rupert Carb
Enderle belt driven fuel pump
Vacuum pump (4-vane doesn't work as hard)
I still have my tank in the rear but I by-pass to the bottom of my pump so there is no return line. I get 0 water in the oil. I have no blow-by, and I feel real bad about changing the oil mid season because it looks so good.
74 Roadrunner 360 cid on alky best 60' 1.442 best ET 10.820 @ 123.23
