Re: Shifter shaft seal replacement on 727
[Re: hemibuzz]
#486920
10/03/09 03:48 PM
10/03/09 03:48 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I had the same problem with the 727 in my 68 C body, I dropped it off at a good trans shop. They pulled the pan and the shaft out and pushed a new on in from the top. About $75 with new fluid and filter.. He said he had done a couple previously..
[Re: Pacnorthcuda]
#486922
10/03/09 06:02 PM
10/03/09 06:02 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I assume you want to do it in car! pan and valve body off. then tap it out from below. then using a piece of 3/8 threaded rod and large washers you set it in place then put rod up through with big washers on top and then a nut on using the threaded rod to pull it down into place!! Think I used a big socket on the bottom has to be bigger than the hole.
[Re: Dodgem]
#486923
10/03/09 08:23 PM
10/03/09 08:23 PM
Posts: 4,707 Florida
BDW
[Re: Dodgem]
#486924
10/03/09 08:29 PM
10/03/09 08:29 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
similar to how i did it, a nut and bolt and two washers,pretty easy.
