Alky jetting #486817
10/03/09 11:59 AM
10/03/09 11:59 AM
Mo.
supercomp Offline OP
Mo.
What size jetting do you run in your 1050 alky carbs. Our lm1 o2 unit says we're rich at 152s. I don't beleive the unit. We were running 188s until we installed the o2 unit.ET hasn't changed. What are your opinions?
Re: Alky jetting [Re: supercomp] #486818
10/03/09 12:06 PM
10/03/09 12:06 PM
ky
68roadrunner Offline
ky
imho it depends on the carb builder what jets it needs do to the way he design the other circuits. i am running 128. makes good heat and burns 1 gal on an 1/8 pass, 5 qts or so on an 1/4 pass
Re: Alky jetting [Re: 68roadrunner] #486819
10/03/09 12:53 PM
10/03/09 12:53 PM
Mo.
Mo.
It's an APD and with all our dragster info they sent 188s and 192s with it. They are holley alky jets.
Re: Alky jetting [Re: supercomp] #486820
10/03/09 04:18 PM
10/03/09 04:18 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
carb builder is critical to jetting. my Apd uses 186-194 and my rupert uses 164. If there was no gain in et or mph I would jet back down.
