4spd OD? #486401
10/02/09 06:48 PM
10/02/09 06:48 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Am I wrong in thinking in the late 70's and early 80's that Dodge trucks had a trans that was a 4 spd ..but 4 th was OD?? I'm talking d150's type pick up's..What # trans and where can I get one ??
Re: 4spd OD? [Re: dynamite] #486402
10/02/09 07:01 PM
10/02/09 07:01 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
not sure on the years produced but yes a833od its off the good ol a833 but alot were aluminum cases and the front bearing retainer is alot bigger so the register or hole needs to be bigger so if you pull the trans get the bellhousing too. also to achieve this and with the gear changes internally the 3rd 4th shift lever is upside down in comparison to the standard 4 speed
Get Real Get Mopar
Re: 4spd OD? [Re: dynamite] #486403
10/02/09 07:58 PM
10/02/09 07:58 PM
Clinton Twp. Michigan
coronet1966d Offline
i have one..well had one. i sold the trans but i still have the 4 speed hump, clutch linkage, bellhousing, pedals and a flywheel for a 360
Re: 4spd OD? [Re: coronet1966d] #486404
10/02/09 08:45 PM
10/02/09 08:45 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
You don't necessarily have to machine the bell housing. We just put one in my brother's Coronet. All we did was machine down the OD of the retainer to fit his existing bell housing. There is plenty of meat on it to do so. This will not work if you have an early bell that has the really small hole. The two of us have used a few of these over the years, and have used the factory O/D bell, machined a bell to fit the retainer, and now machined the retainer to fit the bell. This last time is by far the best way to go so you won't end up with a bastardized bell housing that nobody wants or can use. His is behind a 440.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: 4spd OD? [Re: dynamite] #486405
10/02/09 10:26 PM
10/02/09 10:26 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
A-833 O.D.s were installed in '75.5-'86 trucks and vans. They are not hard to find. Place a want ad in the classifieds here or on your local craigslist.
Re: 4spd OD? [Re: In_The_Pink] #486406
10/03/09 12:37 AM
10/03/09 12:37 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
True that, I have three in the garage.
Don't be the exception.
