Vinyl top install #486392
10/02/09 06:27 PM
10/02/09 06:27 PM
Greenville Pa.
rdagw Offline OP
rdagw  Offline OP
Greenville Pa.
Hi
I am goin to try and install my top myself on my 68 charger. Any tips will be great like what not to do & what to do. thanks
Leo
Re: Vinyl top install [Re: rdagw] #486393
10/02/09 06:32 PM
10/02/09 06:32 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Vinyl top install [Re: Neil] #486394
10/03/09 07:59 PM
10/03/09 07:59 PM
Greenville Pa.
rdagw Offline OP
rdagw  Offline OP
Greenville Pa.
Thanks Neil
Re: Vinyl top install [Re: rdagw] #486395
10/08/09 06:53 PM
10/08/09 06:53 PM
ohio
jaycuda Offline
jaycuda  Offline
ohio
Just take your time trim slowly around the cut off area's.Only trick is have a bondo spreader or other small tool to push in down in the drip rail and leave at least 5/8 under the drip rail or it will be harder to hold down as the contact glue dries. I just use my hand mostly to smooth it its very easy to smooth the large area's it take's time in the small areas b/c you want to get it in pushed down good in the drip rail. It also takes some time to get the wiggles out of the lines (seam's) you just pull hard and look at it good so it's nice. 4hrs to 5 hrs of your time so it's nice. Jay
