Re: what grade of oil do you suggest? [Re: Big B] #485858
10/04/09 02:06 PM
10/04/09 02:06 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Schaffer 5w 50 is some great stuff. Its a fully green synthetic oil..
http://www.schaefferoil.com/engine_oils.html
Re: what grade of oil do you suggest? [Re: Big B] #485859
10/04/09 02:10 PM
10/04/09 02:10 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
I can't believe how expensive Joe Gibbs oil is. $174 for a case of 15w50.(14.50/qt) Brad Penn 20w50 costs me $50. No brainer.
If I were to run an expensive oil it would be Mobil one 20w50 v-twin oil. The offshore raceboat guys swear by the stuff, and is probably the most robust oil made...period! It's only 9.50/qt
Re: what grade of oil do you suggest? [Re: Bob_Coomer] #485860
10/04/09 02:11 PM
10/04/09 02:11 PM
madison, ohio
modified1090 Offline
madison, ohio
i believe that Schaffer also makes a conventional oil used for race that is good, i was told that alcohol won't mix with synthetic oil and should avoid. however joe gibbs web site says that there synthetic will mix with alcohol and is good for NOS
Re: what grade of oil do you suggest? [Re: Bob_Coomer] #485861
10/04/09 02:16 PM
10/04/09 02:16 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
I thought about running Schaffers oil, but found out it had a lot of molly in it.
I heard that molly can cause roller lifters to skid so I passed.
Re: what grade of oil do you suggest? [Re: modified1090] #485862
10/04/09 02:20 PM
10/04/09 02:20 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Brad Penn 50wt and 70wt oils are supposed to be excellent for alcohol too. Go to their websight and read the testimonials.
Re: what grade of oil do you suggest? [Re: Big B] #485863
10/04/09 03:19 PM
10/04/09 03:19 PM
ky
68roadrunner Offline
ky
alot of local racers run schaffers, as a locol machine shop sells it, they have had no lifter problems or skidding. they run 20w50 w/moly
Re: what grade of oil do you suggest? [Re: 68roadrunner] #485864
10/04/09 03:42 PM
10/04/09 03:42 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
I received this ad in the mail yesterday for Valvoline VR1 Racing oil. Anybody know anything about it?
Re: what grade of oil do you suggest? [Re: Hemi_Jack] #485865
10/04/09 11:03 PM
10/04/09 11:03 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
I hear the VR-1 is real good oil! Does anyone know how much zddp(zinc)it has,measured in PPM??? Thanks! RandyB
Re: what grade of oil do you suggest? [Re: Labratt] #485866
10/04/09 11:37 PM
10/04/09 11:37 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
I found this on a google search. This is for the 10W-30. It said it is $8/qt at Autozone.
Synthetic VR-1
40C-64
100C-10.5
HTHS-3.0
TBN-8
Zinc-1400
Phos-1300
Calcium-1910
Sodium-490
SL
