Re: what grade of oil do you suggest?
[Re: Big B]
#485859
10/04/09 02:10 PM
10/04/09 02:10 PM
Posts: 325 Greenville, WI
Big B
Greenville, WI
I can't believe how expensive Joe Gibbs oil is. $174 for a case of 15w50.(14.50/qt) Brad Penn 20w50 costs me $50. No brainer. If I were to run an expensive oil it would be Mobil one 20w50 v-twin oil. The offshore raceboat guys swear by the stuff, and is probably the most robust oil made...period! It's only 9.50/qt
[Re: Bob_Coomer]
#485860
10/04/09 02:11 PM
10/04/09 02:11 PM
Posts: 257 madison, ohio
modified1090
madison, ohio
Schaffer 5w 50 is some great stuff. Its a fully green synthetic oil.. http://www.schaefferoil.com/engine_oils.html
i believe that Schaffer also makes a conventional oil used for race that is good, i was told that alcohol won't mix with synthetic oil and should avoid. however joe gibbs web site says that there synthetic will mix with alcohol and is good for NOS
[Re: modified1090]
#485862
10/04/09 02:20 PM
10/04/09 02:20 PM
Big B
Greenville, WI
Brad Penn 50wt and 70wt oils are supposed to be excellent for alcohol too. Go to their websight and read the testimonials.
[Re: Big B]
#485863
10/04/09 03:19 PM
10/04/09 03:19 PM
Posts: 877 ky
68roadrunner
ky
I thought about running Schaffers oil, but found out it had a lot of molly in it. I heard that molly can cause roller lifters to skid so I passed.
alot of local racers run schaffers, as a locol machine shop sells it, they have had no lifter problems or skidding. they run 20w50 w/moly
