Has anybody used Summit's fuel line like this one?
#485772
10/01/09 10:22 PM
10/01/09 10:22 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Summit fuel line for an E-brockMines leaking.....I haven't used any plumbers tape(which I was always told that's a bad idea). I'm not positive yet if it's the gauge hole or the fuel line side. It's not leaking at the carb.
Moparlee
Re: Has anybody used Summit's fuel line like this one?
[Re: SlimJim]
#485774
10/02/09 08:39 AM
10/02/09 08:39 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
You don't want to seal the thread on that banjo fitting. The washers/gaskets are supposed to do that. Perhaps replace the washers?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#485775
10/04/09 03:49 AM
10/04/09 03:49 AM
Robbins
Joplin, MO USA
Ok, I used Teflon tape on the gauge and the brass nipple in the end of the Summit line and now no leaks. Hopefully it'll stay that way.
Moparlee
[Re: Posest]
#485780
10/05/09 11:40 AM
10/05/09 11:40 AM
CJK440
Ansonia, CT
If the 2 washers on either side of the banjo don't seal, no amount of tape or pipe dope will help.
The threads do not do the sealing with this type of connection so don't waste your time. Fix it right. Look for scored or cracked washers or burrs/cracks on the fitting itself.
[Re: CJK440]
#485781
10/05/09 02:34 PM
10/05/09 02:34 PM
Posts: 15,487 Florida
scratchnfotraction
I have run those a couple times right now I have the duel feed line for a thunder carb and drilled the performer top on the other side and tapped it to work had to put a little tape on the gauge threds on the single line once... washer every time its R&R for sure must have got it if its no leaky now
