Anyone running 8's w/a stock block? #485709
10/01/09 09:28 PM
10/01/09 09:28 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
Anyone running or has run 8's w/a stock block & did it or is it holding up?Filler..... N20.... Turbo....?
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485710
10/01/09 09:34 PM
10/01/09 09:34 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I have but, not in a quarter mile.
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485711
10/01/09 09:39 PM
10/01/09 09:39 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
how heavy of a car?
Re: Anyone running 8's w/a stock block? [Re: blownzoom440] #485712
10/01/09 09:41 PM
10/01/09 09:41 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
MoparBilly did. I'm not sure of his combo but he might chime in. I know it had a little spray to get him there.
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485713
10/01/09 09:48 PM
10/01/09 09:48 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
N/A. 2500lb door car. 383 block with ported 915 heads. No block filler. Not in the 8s but went 9.08 at 148.50. 400+ runs and counting.
Re: Anyone running 8's w/a stock block? [Re: qwkmopardan] #485714
10/01/09 10:44 PM
10/01/09 10:44 PM
ky
68roadrunner Offline
ky
8.10 @ 157 on the chip. but its only 1854 lbs
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485715
10/01/09 10:47 PM
10/01/09 10:47 PM
Ames, Iowa
LoneMopar Offline
LoneMopar  Offline
Ames, Iowa
My 8's were short lived. Ran high 8's for one glorious weekend this spring.
Has run low 9's for 3 seasons.
440 block, N/A only, Filled to water pump holes
BCR aluminum main caps, Steel rods, Never above 34* timing
Re: Anyone running 8's w/a stock block? [Re: qwkmopardan] #485716
10/01/09 10:49 PM
10/01/09 10:49 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Very impressive right there.
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485717
10/01/09 10:49 PM
10/01/09 10:49 PM
Mo.
racerx Offline
racerx  Offline
Mo.
This are to be intresting
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485718
10/02/09 03:24 AM
10/02/09 03:24 AM
WA
JD Dart Offline
JD Dart  Offline
WA
400 block filled to the water pump holes N/A 499 stroker 2630 car best 8.94 before the car it was in a 3550 truck total runs 178 will freshing it up this winter hope all will be ok.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Anyone running 8's w/a stock block? [Re: JD Dart] #485719
10/02/09 05:17 AM
10/02/09 05:17 AM
Q
Quicktree Offline
Quicktree  Offline
Q
we ran 7s with a stock 400 block in a dragster. motor lasted about 2 years and the crank broke in half.
Re: Anyone running 8's w/a stock block? [Re: Quicktree] #485720
10/02/09 09:31 AM
10/02/09 09:31 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
1940 lb dragster 400 block 500ci runs 7.89 n/a 1050 carb. over 500 passes and still going.
Re: Anyone running 8's w/a stock block? [Re: supercomp] #485721
10/02/09 09:57 AM
10/02/09 09:57 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
buddies ride has the 451 kit. stock block.
when he first put it together he was running 8.60's... but after about 105 passes(2yrs)...the crank broke in half loading it on the trailer..
amazing not alot of damage...
rebuilt same block..T-stopped it to run 9-teens
its been together 2 yrs.now...
at the beginning of this season he pulled the pan...and found. main cap issues..
he fixed it,,,,at this level..its alot of stress on that stock block...
its a 2300lb daytona.
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Anyone running 8's w/a stock block? [Re: cheapstreetdustr] #485722
10/02/09 10:05 AM
10/02/09 10:05 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Lenny Melton (8second Dart) has loads of 8second passes on his stock block 451....
TOdd
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485723
10/02/09 10:08 AM
10/02/09 10:08 AM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
Ran 8.70's with a stock block 400/499 with Indy 440-1's on spray, Dart weighed 3450 with me in it. Tall fill, Pro Gram caps, Oliver rods. Wound up hurting the pistons in it but thats just because they weren't set up for spray. If I was to do another stock block, it would be with aluminum rods and main caps.
LBSR
Re: Anyone running 8's w/a stock block? [Re: sasquatch] #485724
10/02/09 10:10 AM
10/02/09 10:10 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
2570 lbs, naturally aspirated, only two runs in this chassis, 8.9's The short block has been in use in different cars since 2002 and th eenigne in its current state of tune from 2004. Pump gas, of course.
http://www.kuvia.1g.fi/kuvat/Tapahtumat+2009/FHRA/DefaFinals/MOP_7172.jpg
http://www.kuvia.1g.fi/kuvat/Tapahtumat+2009/FHRA/DefaFinals/MOP_7777.jpg
400 block, low fill (to half way of the freeze plugs) and aluminum main caps.
Plynouth VIP '67 TT IC EFI
Re: Anyone running 8's w/a stock block? [Re: jyrki] #485725
10/02/09 10:32 AM
10/02/09 10:32 AM
oh
julian2007 Offline
julian2007  Offline
oh
1800 lb dragster 520 69 hp block stud girdle alum main caps 8.02 at 166.00 mph
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Anyone running 8's w/a stock block? [Re: mrart01] #485726
10/02/09 11:43 AM
10/02/09 11:43 AM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
Up until about three years ago every SS/AH guy used a factory block. Most, if not all, of the new engines use the new World block, but it is still similar to a factory one. When Jim Pancake set the record in 2006 with his Cuda @ 8.55 & 155 it was a stock block. 3210 lbs.
Re: Anyone running 8's w/a stock block? [Re: Ben Holt] #485727
10/02/09 11:46 AM
10/02/09 11:46 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
They have the advantage of cross bolted mains though.
The stock block may hold up for awhile, but it will eventually split down the mains and then into the cylinder walls. Ask me how I know.
Re: Anyone running 8's w/a stock block? [Re: sixpakdodge] #485728
10/02/09 11:51 AM
10/02/09 11:51 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Are you really sure about the stock block in SS/AH cars? As far as I remember, when Bartons first were the "big dog" in SS Hemis, they credited the new more rigid and thicker deck blocks for much of the added performance. The new blocks allowed them to mill somne 3/8+" of the decks too which helped with the enormous piston weight. That must be some 10 years ago?
