less wheelstand with ladder bars, which hole???????
#485544
10/01/09 07:56 PM
10/01/09 07:56 PM
does top hole hit the tires softer or harder and if i put the bar in the top hole will it wheelstand higher? i like the chassis engineer triple adjustable outlaws?
Re: less wheelstand with ladder bars, which hole???????
#485545
10/01/09 09:52 PM
10/01/09 09:52 PM
doesnt anyone run ladder bars here? im new on here.
Post deleted by Defbob
[Re: wheelsup68dart]
#485547
10/01/09 10:01 PM
10/01/09 10:01 PM
#485548
10/01/09 10:03 PM
10/01/09 10:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ladder bars have a fixed IC length, if you go up on the fronts it hits the tire harder.... lower is a softer hit but it sustains the hit longer Welcome to the jungle
[Re: MR_P_BODY]
#485549
10/01/09 10:12 PM
10/01/09 10:12 PM
Posts: 877 ky
68roadrunner
ky
x2
you can try to control the wheelstand with the front shocks tighten them up(harder to extend). and even tie the front end down if it will work.
#485550
10/01/09 10:54 PM
10/01/09 10:54 PM
Posts: 166 Ames, Iowa
LoneMopar
Ames, Iowa
sorry for not replying quickly I was in the potty
Get a laptop!
[Re: LoneMopar]
#485551
10/02/09 12:53 AM
10/02/09 12:53 AM
Posts: 2,864 IN
Irun5snd8th
IN
Its worth mentioning that softening the compression on the rear shocks will also lessen a wheelstand.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: MR_P_BODY]
#485553
10/02/09 09:51 PM
10/02/09 09:51 PM
dartman366
Mt. Vernon, Ohio
That the result I got when I dropped the ladder bar down 1 hole, didn't pull them up as high but held them up farther down track.
[Re: Irun5snd8th]
#485554
10/02/09 11:24 PM
10/02/09 11:24 PM
Posts: 7 AB Canada
Demon Guy
AB Canada
Did you mean softing the compression or the extension, I always thought softing the extention would lessen the wheelstand, please elaborate. Thanks
71 Demon 451 SR All Motor
Chassis car 2475 w/driver
Best ET 9.08 @ 150.05, 4787 Corrected Alt
