nitrous #485512
10/01/09 07:39 PM
10/01/09 07:39 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
what kind of systems you guys use? im kind of thinking towards a small plate system, nothing exotic. around 150 to 200hp shot. something for a 340 with w2s. any ideas or tips appreciated.
Re: nitrous [Re: Uncle Barry] #485513
10/01/09 07:46 PM
10/01/09 07:46 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
Something simple, non-exotic would be a NOS cheater kit.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: nitrous [Re: juicedcuda] #485514
10/01/09 11:06 PM
10/01/09 11:06 PM
U
U
is NOS the best nitrous kit or are there different brands of plate systems that are better? sorry for the dumb questions, im not up on this stuff yet.
Re: nitrous [Re: Uncle Barry] #485515
10/01/09 11:18 PM
10/01/09 11:18 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I'v purchase a Zex perimeter plate system.Hoping to spray it this weekend.
Re: nitrous [Re: racerx] #485516
10/02/09 08:02 PM
10/02/09 08:02 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Re: nitrous [Re: Hot 340] #485517
10/02/09 08:30 PM
10/02/09 08:30 PM
UK
602heavy Offline
602heavy  Offline
UK
I use Nitrous Express systems , great jet spread out the box , also rear wheel HP , the perimeter plates are the best IMO , these plates use fuel pressures between 8-10 psi.
FWIW , always use solinoids supplied with the kits , never mix & match unless you know what both sets flow.
Re: nitrous [Re: Uncle Barry] #485518
10/02/09 09:28 PM
10/02/09 09:28 PM
Colorado
506RR Offline
506RR  Offline
Colorado
Contact Monte Smith here on the board. He is the MAN when it comes to nitrous kits. He will get you set up with exactly what you need.
I use an NOS plate system from him, and am loving it!
Re: nitrous [Re: juicedcuda] #485519
10/02/09 09:39 PM
10/02/09 09:39 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Like this.....
Re: nitrous [Re: 506RR] #485520
10/02/09 10:31 PM
10/02/09 10:31 PM
Ma
Voluster Offline
Voluster  Offline
Ma
X2
I use one of the double cross bar plates on my small block
Re: nitrous [Re: Uncle Barry] #485521
10/03/09 03:57 AM
10/03/09 03:57 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If your getting a new matched kit, you should not have problems. If you are buying used parts, then buyer beware.... Also, the aluminum tanks are supposed to be pressure tested every five years.
The place re-filling the tanks are not supposed to fill an out of date tank. I don't know how much it costs to have the tank pressure tested. I used to pressure test gas cylinders as a summer job when in collage, but that was over 20 years ago...
Re: nitrous [Re: CRE2004] #485522
10/03/09 10:26 AM
10/03/09 10:26 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Like this.....
Betcha it aint tuned like this untrick setup @ 8:15... http://www.youtube.com/watch?v=oawspa5EVzs&feature=related
Re: nitrous [Re: Hot 340] #485523
10/03/09 10:34 AM
10/03/09 10:34 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Plate kits are as simple as they get, even on a six pack. I run a super small plate kit on the six pack and if that wont do it you can always hitem hard with the hidden kit, either is easy to use and understand. Although ive only used both kits together 3 times.
