Which locks to use on Indy valves ?? #485288
10/01/09 04:35 PM
10/01/09 04:35 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Indy use an 11/32" valve stem and so far I've only found locks for 3/8" valves. Are they ok or do I have to use 11/32 locks?
Re: Which locks to use on Indy valves ?? [Re: Stanton] #485289
10/01/09 06:06 PM
10/01/09 06:06 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Only use the correct locks 11/32.Comp Cams,Summit ,Jegs,Indy or any dealer.Make sure they are compatable with your retainers,7 degree,10degree,etc.Some have different lock locations for retainer height setting.
Re: Which locks to use on Indy valves ?? [Re: B G Racing] #485290
10/01/09 06:21 PM
10/01/09 06:21 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I just didn't look hard enough ... they aren't listed with the Mopar stuff, you have to look under "locks".
Thanks !!
