At the crossroads - kind of long read #485157
10/01/09 01:58 PM
10/01/09 01:58 PM
MO
Griffin Offline OP
Griffin  Offline OP
MO
OK, I finally got me a project and now that I have it and have looked over it, I am at the proverbial crossroads.
Background: Last November, I sold my 1956 Pontiac that I'd had for over 18 years. It was all stock with a very minor customization (springs, blackwall radials). It was too nice to really cut up and do anything else to than leave stock.
Fastforward to now: Since I had my 50's stocker, I've been wanting to do a '48 or prior hot rod. Last Sunday, I acquired a relatively cherry 47 Dodge 1 ton that has a very minimal amount of rust in areas that are completely fixable and with an engine that supposedly just needs the crank ground and new bearings. It was a barn find and will need the brake system overhauled as well as the wheel seals (I'm sure) and new weatherstripping.
Well, last night, I was looking it over and measuring the engine bay to see how a later model V-8 would fit, and also looking underneath to get an idea of what it'll take to drop it down from the altitude that it has.
My delima: Since it is in such good condition, there is a part of me that has a problem with changing it from stock. But then there's the rodder side of me that says, "It's my truck - I'll do what I want" and doing what I want will be an indepth change (ie chassis, powertrain, etc).
So tell me - what would moparts do?
Re: At the crossroads - kind of long read [Re: Griffin] #485158
10/01/09 02:13 PM
10/01/09 02:13 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Put a poll on here ..
My vote, hot rod it ..but, please use a Mopar motor
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: At the crossroads - kind of long read [Re: Griffin] #485159
10/01/09 02:47 PM
10/01/09 02:47 PM
MO
Griffin Offline OP
Griffin  Offline OP
MO
You decide
single choice
Votes accepted starting: 10/01/09 01:47 PM
Re: At the crossroads - kind of long read [Re: Griffin] #485160
10/01/09 02:52 PM
10/01/09 02:52 PM
CA - Lord help us!
GTXperience Offline
GTXperience  Offline
CA - Lord help us!
Griffin, you don't need us to tell you what to do with it. If you haven't figured it out yet, you will. Deep down, we all have a pretty good idea what we want to do with our projects (money and/or time permitting). As you have all ready mentioned, it's yours to do with whatever you want with it. Whichever route you go, you can't go wrong. It's going to be one cool ride either way. Good luck.
Re: At the crossroads - kind of long read [Re: Griffin] #485161
10/01/09 02:59 PM
10/01/09 02:59 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Rod it!
It is hard to find examples of nicely done Dodge pick ups.
I've got one to build too, I just need to finish some other stuff before I can get to it.
Re: At the crossroads - kind of long read [Re: Flipper1938] #485162
10/01/09 03:29 PM
10/01/09 03:29 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
My answer? A little of both!
The finish looks pretty decent, you could clean it up and do a little light refinishing on the body. "Patina" is in right now.
Make the steering, brakes, and wheel/tires safe, because those things can kill ya!
As far as the rest of the drivetrain goes, decide what you want out of it before you change it up to much. I get the feeling that a hopped up driver is what you're after, so a V8 swap might be in order, but if the stock engine runs you might just mill the head to raise compression, add a dual carb intake and split exhaust with Smithys.
That's just my take. I like V8 swaps, but I dig the "old-timey" stuff, too.
Re: At the crossroads - kind of long read [Re: Griffin] #485163
10/01/09 03:43 PM
10/01/09 03:43 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Thats really tough. It's easy to rod something that isn't mint to start with. This truck has made it 60 years in good shape so you don't want to mess it up. I think I would take the frame and store it, then build a new frame with modern stuff and restore the body but with a fresh interior and put it on the frame. Chances are you would never put the body back on the stock frame but in the back of your mind you would know that you could if you wanted to.
Sheldon
Re: At the crossroads - kind of long read [Re: Griffin] #485164
10/01/09 03:59 PM
10/01/09 03:59 PM
Nort Cackalacky
rrbrucea Online penguin-006
Member known as the "Artist"
rrbrucea  Online Penguin-006
Nort Cackalacky
Rod the heck out of that thing! Just don't put a SBC in it... FWIW, I know someone who found one very similar that only had 4700 miles on it. Seriously! That one deserved to be restored, but yours deserves to be rodded!
Re: At the crossroads - kind of long read [Re: rrbrucea] #485165
10/01/09 04:11 PM
10/01/09 04:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'd build it for it's intended usage.
Summer night town and country cruisin'? Freshen it up and enjoy.
Light haulin at slow speeds? The same, but upgrade the brakes.
Freeway miles and roddin'? Suspension, electrical, brakes and drivetrain, plus some comfort inside (seat, insulation, sounds)
I'd get into a chassis swap only if it was going to be a major rod project. The radiator is almost even with the front axle, so a Dakota can be made to work, but the drivetrain has to be moved back.
Lots of work that way, but if you want modern handling, air suspension, and all that, it could be done. You could add all that to the original chassis too.
Re: At the crossroads - kind of long read [Re: RodStRace] #485166
10/01/09 06:55 PM
10/01/09 06:55 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
That thing is just screaming for a Cummins drivetrain. Maybe even 4wd
Re: At the crossroads - kind of long read [Re: Griffin] #485167
10/01/09 08:24 PM
10/01/09 08:24 PM
kansas city, mo.
mikeinkc Offline
mikeinkc  Offline
kansas city, mo.
since it is so complete, i say fix the mechanicals and drive it as is and restore slowly. you can always find a cab to make a hot rod out of. besides, you might need to use it as a truck someday!!!
ask me about new sportone elbow side trim for your 1957 and 1958 plymouths http://39lowboydodge.blogspot.com/
Re: At the crossroads - kind of long read [Re: mikeinkc] #485168
10/01/09 09:40 PM
10/01/09 09:40 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You need to get rid of that beast. You can send it to me, I won't have any issues making a rod out of it.
I have a nice 70 pickup frame, a running slant 6, and will soon have an OD 4 speed just waiting for something like that to come along. Gene
Re: At the crossroads - kind of long read [Re: mikeinkc] #485169
10/01/09 09:42 PM
10/01/09 09:42 PM
WA 98043
thecarfarmer Offline
WA 98043
Guess what I voted...
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: At the crossroads - kind of long read [Re: thecarfarmer] #485170
10/02/09 01:27 AM
10/02/09 01:27 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i agree with the owner,,,hard choice both would be kool, not many around stock or rodded properly. there are more of that vintage rat rodded then restored, what a waiste of metal and sawzal blades,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: At the crossroads - kind of long read [Re: Griffin] #485171
10/02/09 09:50 AM
10/02/09 09:50 AM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
From the Mopar rod picture thread.
Not the same model but close enough to inspire...
Re: At the crossroads - kind of long read [Re: Flipper1938] #485172
10/02/09 01:11 PM
10/02/09 01:11 PM
MO
Griffin Offline OP
Griffin  Offline OP
MO
Yeah, I've seen that one. It's real nice, but it looks like it has a SBC in it. I won't commit such a travesty. I'll keep it MoPar
Re: At the crossroads - kind of long read [Re: Griffin] #485173
10/03/09 06:00 PM
10/03/09 06:00 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Seen at good guys here this weekend
Re: At the crossroads - kind of long read [Re: bigdad] #485174
10/04/09 12:28 AM
10/04/09 12:28 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
That's a beauty. A mild custom would still keep most of the originality and if you do a clean job of putting in late model drivetrain (6.1L Hemi would be sweet), you could always convert back if the next owner wants the restoration.
Did you run into Robert Johnson down at the crossroads?
Floyd Lippencott IV
Re: At the crossroads - kind of long read [Re: mr_340] #485175
10/19/09 01:37 PM
10/19/09 01:37 PM
MO
Griffin Offline OP
Griffin  Offline OP
MO
Thanks for all of the input.
Here's my next question: I got a smokin' deal on a BBC (413 Chrysler, that is), 727, Dana 70 with duals (on a motorhome chassis). My 1st inclination is to just run a single rear wheel. How do ya'll think running the 47 with duals in the rear would look?
Any others out there with the same (running duals on a 39-47 truck)? I'd tub the bed so that the fenders aren't altered.
Re: At the crossroads - kind of long read [Re: Griffin] #485176
10/19/09 03:23 PM
10/19/09 03:23 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
If you are gonna make it a dually, build it as a flatbed.
I think it would look great (my 41 is gonna get the flatbed tratment)
