Re: 87 octane small block stroker?
[Re: kielbasa]
#485095
10/01/09 01:31 PM
10/01/09 01:31 PM
Posts: 79 montreal, quebec, canada
jimmy71demon
this may not be the most educated answer, but when i ran my 340 (.040 over, mild cam, and slightly ported heads) i always ran super (91 octain) cause it didnt seem to like regular 87. now i have almost completed my 416 stroker build, and i will only be running super.
Im goin fast Mom!
[Re: kielbasa]
#485096
10/01/09 01:32 PM
10/01/09 01:32 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I'm curious to see the replies on this one. I'm a fan of daily running on the lowest grade (cost) fuel, and racing on the highest pump grade. Most engine builders I've talked to question why anyone would build a motor like that. My answer is that I've watched the octane rating drop thoughout the years and the price of fuel go up. Not everyone builds a race engine, but most tend to race the engine they build.
I built an 87 octane RB that is alot like a 2.2 engine. By that I mean a cast block and aluminum heads, with about 9.3 compression. I chose a cam and chassis for broadest torque where I drive the most. The torque is shameless, the chassis hooks with DOT's, and is a joy to drive. No tall gears or high stall converter required. Low 12's with high 11 mph at 4,000 lbs.
I think I know what you are after, but I haven't done it with a small block yet.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: Intense RT Dan]
#485099
10/01/09 03:48 PM
10/01/09 03:48 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would say it's possible but why? When you run higher compression you will get slightly better miledge and you can run almost 1 full point higher on premium than cheapy crap. It will also make more power and TQ and you will feel better when you try to I did this on my MPG experiment engine and it basically pays for it self. It also is nice because thease type of builds don't get great miledge so you won't have to stop to fill it quite as often
[Re: RapidRobert]
#485107
10/02/09 11:26 AM
10/02/09 11:26 AM
Posts: 4,748 Florida
BDW
I think it would be neat to find a killer combo that's compatible with 87 octane cheapie gas.
Stay with it. I am also building (albeit very slowly) a 408 w mag heads that I want to run on 87. Tight quench for sure & undecided on cam & final CR.
Please post results, in the future higher octane gas will be harder and more expensive to get.
I've often wondered what's a good compromise for a daily driver, that you actually drive.
[Re: BDW]
#485108
10/02/09 12:28 PM
10/02/09 12:28 PM
Posts: 3,054 USA
b54406barrel
USA
I can’t help on a small block but my 6bbl/440 is 8.6 to 1, cranks @ 150-155 lbs, weighs 4160# with me in it and runs 13.1 @ 107. Auto, 3:23’s, full exhaust & 215/70 radials. Just has a little head work, Hughes 215/223, 112-lsa cam, headers & low compression pistons. Went low compression many-many years ago, ('quench' was a new word. ) around the time leaded got hard to get. I drive a lot, wanted cheap gas & vacuum advance. I can get as high as 16 mpg @ 70 and always run 87 gas.
[Re: kielbasa]
#485110
10/02/09 02:40 PM
10/02/09 02:40 PM
HotRodDave
Kalispell Mt.
I don't beleive the octane rateing would increase MPG at all unless your timing was too far advanced for your 87 octane or if you had so much compression it was pinging on 87.
What I am saying is that you can increase the compression at least 1 full point if you are willing to run premium. Increased compression is pretty well documented to increase MPG a very noticable amount. It is also a proven way to increase HP and TQ. So in short you run higher compression and higher octane together to get better MPG, yes it costs more but the increased MPG offsets most if not all of it.
[Re: kielbasa]
#485112
10/02/09 04:25 PM
10/02/09 04:25 PM
My 360 with 10.7 to 1 comp,and my 416 with 11.9 to 1 comp. run just fine on 93 octane gas,using aluminum heads..
