Mopar 528 and 557 Solid Cams #484919
10/01/09 06:18 AM
10/01/09 06:18 AM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
Which one of these would be the better cam for a good STRONG street/strip car using 915/906 heads? Or is there even better cams than these that are proven winners? Thanxs
Re: Mopar 528 and 557 Solid Cams [Re: JohnnyBeGood] #484920
10/01/09 07:13 AM
10/01/09 07:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I running the 528 w/ 1.5 roller rockers in this 440-6. seems to pull pretty good. I'm hoping for 12.4's or better. We'll find out soon. I bought the short block w/ the cam installed. I might have gone bigger if I did it form scratch. It's a nice mellow cam that seems to have a good range. I did go tighter on the lash than directed. The 557 seems to be a good cam as well. There are plenty of people on here running in in B-bodys and pull 11's. I guess it would depend on the rest of your set-up. A 557 is going to need more gear and more converter.
Coming soon!!!!
Re: Mopar 528 and 557 Solid Cams [Re: Mr.Yuck] #484921
10/01/09 09:06 AM
10/01/09 09:06 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I to run a 528 in a hot 470" motor. HAD a bigger Comp cam it but changed it (and the sgl plane intake to Edelbrock RPM dual plane) to make it more "streetable". Still able to smke the tire and even keep up (for a bit) with a crotch rocket from a stop light.
I REALLY like this cam.
Re: Mopar 528 and 557 Solid Cams [Re: 71TA] #484922
10/01/09 09:41 AM
10/01/09 09:41 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
The 528 is a nice manner streetable cam that isn't a real radical cam. Doesn't have as much in it as the 509 hydraulic though as it is really a lesser cam after you take teh lash off you end up with like 500 lift. The .557 will give you alot more but will not be quite as street friendly.
Re: Mopar 528 and 557 Solid Cams [Re: MoparforLife] #484923
10/01/09 10:13 AM
10/01/09 10:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
unless you set the lash at .022-.026
Coming soon!!!!
Re: Mopar 528 and 557 Solid Cams [Re: Mr.Yuck] #484924
10/01/09 10:28 AM
10/01/09 10:28 AM
Upper Midwest
Upper Midwest
Even at .022 and .026 it will net less than the 509. Not mush but less. It will be 506/522.
Never the less the seasonal running of each in the same engine, same car netted up to 2 tenths average less ET with the .528 but better mannered.
PS: that is even trying various lash adjustments.
Do what you want. For the street I would chose a 509. For more strip than street the .557.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Mopar 528 and 557 Solid Cams [Re: MoparforLife] #484925
10/01/09 10:34 AM
10/01/09 10:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
509 needs more stall than I wanted to run and doesn't work as well down low and pulls terrible vacuum. And this cam was already in the car.
Coming soon!!!!
Re: Mopar 528 and 557 Solid Cams [Re: Mr.Yuck] #484926
10/01/09 10:56 AM
10/01/09 10:56 AM
Upper Midwest
Upper Midwest
Basically what I was saying. IMO you will very likely be happier then with the .528. It really isn't that bad a cam, just depends on what you are looking for.
Re: Mopar 528 and 557 Solid Cams [Re: MoparforLife] #484927
10/01/09 01:59 PM
10/01/09 01:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would consider the 528 and 557 to both be good street/strip cams. With the 528 being much more towards street and the 557 leaning much more towards strip. If you have an iron headed big block, the 528 is good if you've got 8-9:1 compression, stock or mild stall and mild gears, or exhaust manifolds, etc. The 557 is more suited to 10+:1 compression, headers, high stall converter and steep rear gears.
Re: Mopar 528 and 557 Solid Cams [Re: DaytonaTurbo] #484928
10/02/09 02:26 AM
10/02/09 02:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The .528 works real good if you are running exh manifolds. But as was said it sounds very mild in a bigblock and with headers the .557 will make more power in a mild street/strip combo. I run the .557 in my 63 and we have one in my boys Dart. Myself I think they are a nice street cam as the idle really is not that radical after it warms up. It is very easy to live with running the 9.5 Dynamic converter my son and I use. I would consider running much more cam in my street car as I guess I am so used to the .557. But it makes great power in our cars. My son runs 3.91's in his Dart and I run 4.30's with a taller tire then him. Both cars have great low end and pull nice up top for a mild street combo. If you want a mild idle with good power use the .528 but if you want alot of power and a choppy idle go with the .557 as long as your combo will support it. Ron
Oh I forgot to tell you I use 906 heads and run 10.0 comp and it runs fine on 92 pump.
