radiator question
#484713
09/30/09 07:53 PM
09/30/09 07:53 PM
Posts: 12 ireland
mitchdublin
ireland
Hi, i have been looking at getting a new rad, any i looked at had top hose on passenger side. Mine is on drivers. Is this a smallblock rad?. Car is a 72 satellite with 440 Rb engine. Car running a bit hot, think rad is blocked, which rad would you guys suggest for maximum cooling. Thanks Mitch
Re: radiator question
[Re: mitchdublin]
#484714
09/30/09 08:23 PM
09/30/09 08:23 PM
RapidRobert
If you can find a shroud that will fit your rad & a properly spaced thermal clutch fan you may be Ok as is. When does it run a bit hot? idleing, slow speeds, high speeds. Might take the stat out for 1 day.
[Re: RapidRobert]
#484715
09/30/09 08:31 PM
09/30/09 08:31 PM
Posts: 12 ireland
mitchdublin
ireland
Hi, car runs at 200-220, spikes sometimes to 240, i have two 12" electric pusher fans. still stays at 200. idle or driving at 60mph. Only have 3 3/4" clearance between pulley and rad. was thinking a fixed fan maybe?
[Re: mitchdublin]
#484716
09/30/09 08:58 PM
09/30/09 08:58 PM
RapidRobert
I'd toss the stat for one day. It might be partially stuck & if so it'd be an easy fix. No issue w the timing/mixture & plugs look OK? Has it always ran slightly hot or was it OK & gradually deteriorated? At 60 mph I would assume no lack of airflow but nothing is keeping the air from reaching the fins? www.speedwaymotors.com and others have universal alum 3 core radiators for reasonable money. EDIT Read the "shorter fan clutch" thread on this page.
[Re: RapidRobert]
#484717
09/30/09 09:22 PM
09/30/09 09:22 PM
Posts: 12 ireland
mitchdublin
ireland
I pulled thermostat, no difference. car has ran hot since i bought it. one thing i noticed is that my distributor has no vacuum advance. I set timing at 12 deg, plugs looked ok.
[Re: mitchdublin]
#484718
09/30/09 09:28 PM
09/30/09 09:28 PM
RapidRobert
If your mechanical adv is Ok yes I would be inclined to suspect the rad.
