Page 4 of 4 1 2 3 4
Re: what brand of crank are you running? [Re: an8sec70cuda] #484421
10/01/09 05:37 PM
10/01/09 05:37 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
My Bryant, was $3641
Good Lord! I knew they were high, but I didn't think that high!
My Callies 4.5" stroke, 2.2" rod journals, 8 bolt hemi crank was around $1800. CHIP
Ya, I was planning to get one. Callie had just stopped making forged cranks when I went to order mine. then they made some just after I received my Bryant
Re: what brand of crank are you running? [Re: Scotts71chall] #484422
10/01/09 05:41 PM
10/01/09 05:41 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
about how much for a bryant 4.500 hemi crank?
Callies?
Crower?
I just noticed this must be out of a smart car, since you have it plugged in.
Re: what brand of crank are you running? [Re: maxie] #484423
10/01/09 06:36 PM
10/01/09 06:36 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Re: what brand of crank are you running? [Re: maxie] #484424
10/01/09 06:40 PM
10/01/09 06:40 PM
WI.
Scotts71chall Offline
WI.
Im thinkin it will put out 800 jiggawatts of Hydro magnetic hemiamps before a 300 shot of giggle juice.
Re: what brand of crank are you running? [Re: maxie] #484425
10/01/09 07:29 PM
10/01/09 07:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stock 413 forged crank w/cut counter weights to fit a 400 block at a 3.900 stroke going on 9 years.
Re: what brand of crank are you running? [Re: Thumperdart] #484426
10/01/09 07:37 PM
10/01/09 07:37 PM
running a crower supwer lite weight, gun drilled,knife edges crank 4.75 stroke, just as nice as a bryant imo.
Re: what brand of crank are you running? [Re: maxie] #484427
10/01/09 11:10 PM
10/01/09 11:10 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
K1 4.5" un tested as of yet .Checked out great.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: what brand of crank are you running? [Re: Hemi Allstate] #484428
10/01/09 11:39 PM
10/01/09 11:39 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Winberg. 4.187" stroke, so I'm told. Have to measure it when it's apart for freshening. S/F....Ken M
Re: what brand of crank are you running? [Re: EchoSixMike] #484429
10/02/09 12:36 AM
10/02/09 12:36 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
First was a cast eagle, thought it was enough for a pickup, guess not....
The new one is a Scat stage 1 lightened. This thing looks beautiful!
Re: what brand of crank are you running? [Re: dodgeboy11] #484430
10/02/09 04:31 AM
10/02/09 04:31 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Wow, looks like you dodged a bullet and were lucky a rod didn't decide to exit stage left.
Re: what brand of crank are you running? [Re: maxie] #484431
10/02/09 07:58 AM
10/02/09 07:58 AM
NC
440Jim Offline
440Jim  Offline
NC
Callies
4.250" stroke, with 2.2" rod journals.
Re: what brand of crank are you running? [Re: dodgeboy11] #484432
10/02/09 08:55 AM
10/02/09 08:55 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Little bit of JB weld and that baby is like new. lol
One day I will have something cool here.
Re: what brand of crank are you running? [Re: sdaurity] #484433
10/02/09 10:38 AM
10/02/09 10:38 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Can you run a lightened crank with the hemi? The crank currently in mine had to have weight added to it. I have the eagle crank with manley rods and J and E pistons.
Re: what brand of crank are you running? [Re: maxie] #484434
10/02/09 12:37 PM
10/02/09 12:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can but you need to be able to balance it and hemi's have a heavy bobweight because of the piston size, use a longer rod and you can make the piston smaller to help .
I had a scat/MP low deck stroker crank , it didn't fit in the block because of the counterweight diameter . After looking at it best I could figure is it was a HEMI RESTO crank , it was 5140 , wit hthe mains cut down only . I had to cut a 1/4 inch plus off the counterweight diameters to get it to fit which worked out well as it only needed 2 small holes to balance to my 2200 gram bobweight .
Re: what brand of crank are you running? [Re: maxie] #484435
10/02/09 12:56 PM
10/02/09 12:56 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
I am. I'm running a 440source lightweight crank with gun drilled mains and cut counterweights. Worked good for years although the thrust bearing on the last rebuild was marginal. Also, at Norwalk CC I started to lose oil pressure and had slowed down by almost a half a second. I think I might have trashed a thrust bearing. The bad part about it is 440source doesn't make a lightweight 4.15 stroke anymore so if it's toast I don't know what I'm going to do???
I haven't had the time/motivation to pull the pan. Oh, and it did balance at around a 2300 bob weight.
This post is available in double vision where drunk.
Re: what brand of crank are you running? [Re: Scotts71chall] #484436
10/02/09 05:01 PM
10/02/09 05:01 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I just bought a callies crank from Mancini racing. It was in the chrysler engineering sale. It is new, never used, but needs to be .010 on the rods. I gave $500 for it. I am
Re: what brand of crank are you running? [Re: Bigcube] #484437
10/03/09 04:09 AM
10/03/09 04:09 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Yeah, tell me about it! It actually kept running and got me home another 6 or 8 miles down the road. Idled it, between 800 and 950 rpm. Long 6 or 8 miles let me tell you. Hindsight, should have shut it off and called my one friend in the area to come tow me home. Further hindsight, never should have a bought an eagle cast crank... Or cat rockers for what that's worth...
Re: what brand of crank are you running? [Re: maxie] #484438
10/03/09 10:47 AM
10/03/09 10:47 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
DTHemi did at 654ci
Page 4 of 4 1 2 3 4
