Page 2 of 4 1 2 3 4
Re: what brand of crank are you running? [Re: maxie] #484381
09/30/09 09:01 PM
09/30/09 09:01 PM
440 source
Re: what brand of crank are you running? [Re: mopar376d] #484382
09/30/09 09:05 PM
09/30/09 09:05 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Ohio Crankshaft. Both Cars
Same here!
Re: what brand of crank are you running? [Re: Harley] #484383
09/30/09 09:42 PM
09/30/09 09:42 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Bryant 4.150
Bryant 5.00
Re: what brand of crank are you running? [Re: Diablo] #484384
09/30/09 09:56 PM
09/30/09 09:56 PM
Colorado
506RR Offline
506RR  Offline
Colorado
440Source 4.25
Re: what brand of crank are you running? [Re: 506RR] #484385
09/30/09 09:58 PM
09/30/09 09:58 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
Bryant
Shawn Jennings
Re: what brand of crank are you running? [Re: 572_dup2] #484386
09/30/09 10:00 PM
09/30/09 10:00 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Bryant 4.25
Re: what brand of crank are you running? [Re: 506RR] #484387
09/30/09 10:02 PM
09/30/09 10:02 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
BRC 54lb. 4.5 stroke
Re: what brand of crank are you running? [Re: 540dust] #484388
09/30/09 10:04 PM
09/30/09 10:04 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I went to the Ohio crankshaft website and their part numbers are identical to eagles
There 4.150 crank is $595.
I was on the eagle website earlier today and they have a factory second for $599 plus shipping. I saw a eagle vendor on ebay with a 4.150 crank, not a factory second, for $616 with free shipping.
Re: what brand of crank are you running? [Re: maxie] #484389
09/30/09 10:52 PM
09/30/09 10:52 PM
hartsburg mo
biggerredz71 Offline
hartsburg mo
4.25 440 source
Re: what brand of crank are you running? [Re: maxie] #484390
09/30/09 10:53 PM
09/30/09 10:53 PM
WA 98043
thecarfarmer Offline
WA 98043
I've heard that those early Eagle 'blems' that came .010/.010 were pretty good cranks. They got re-ground locally because they arrived at Eagle with taper on the journals.
I bought a 4.25" B-motor crank from the Sourcerers; (had taper which Brandon paid to have corrected, and was wide on the thrust, which had to be ground .010 wider). I don't recall the weight; I paid for the pendulum-cut counterweights and scalloped flange.
Apart from the finish machining on the journals, it didn't look like a bad piece.
I can't remember what the bobweight was on the balance ticket; think it was around 1750-1800 grams (all Source parts), so I'd expect that it would balance easy enough if you don't have heavy pistons.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: what brand of crank are you running? [Re: thecarfarmer] #484391
09/30/09 11:42 PM
09/30/09 11:42 PM
My first good stroker was a Ohio Crankshaft 4.25 2.200 rod size for a low deck, the second one was a 4.375 Crower lightweight with Mopar journals, the last one was a 4340 CAT 4.15 offset ground to 4.300 with BB chevy rod sizes, it is in the car now My next one will be a 440 Source 4.375 to replace the Crower in the 527 and I will have the Crower offset ground to 4.500 stroke with BB Chevty 2.200 rod journal size to go in the 4.5 bore size World block with the B1 heads
Re: what brand of crank are you running? [Re: Cab_Burge] #484392
09/30/09 11:45 PM
09/30/09 11:45 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
scat
Re: what brand of crank are you running? [Re: Cab_Burge] #484393
09/30/09 11:46 PM
09/30/09 11:46 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
ohio crankshaft ..... 4.30 stroke
1.39 9.85 - 137 mph
Re: what brand of crank are you running? [Re: Ari440] #484394
10/01/09 12:17 AM
10/01/09 12:17 AM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
I went with a K1 crank 4.25 stroke but have not run it yet.
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: what brand of crank are you running? [Re: cudabin] #484395
10/01/09 12:21 AM
10/01/09 12:21 AM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Bryant 4.5
Callies 4.75
Re: what brand of crank are you running? [Re: 604 Hemi GTX] #484396
10/01/09 01:13 AM
10/01/09 01:13 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
Bryant 4.5" billet , ultra light !!!!!!
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Re: what brand of crank are you running? [Re: NENE] #484397
10/01/09 05:37 AM
10/01/09 05:37 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i bought a source & an eagle crank & sent them both to a metalurolist for testing. his opinion was use the source crank, he felt the treatment on the eagle made it more brittle & more likely to crack than the sources crank. shame really as i thought the eagle was a better finish. i'm using the source as suggested.
Re: what brand of crank are you running? [Re: rebel] #484398
10/01/09 06:52 AM
10/01/09 06:52 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
4.15 Ohio in the big block Challenger.
4.00 K1 in the small block Dart Sport.
Both checked out perfect.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: what brand of crank are you running? [Re: Jacob Pitt] #484399
10/01/09 07:04 AM
10/01/09 07:04 AM
Netherlands
72Challenger Offline
Netherlands
4.15 MP in the Challenger
OEM MP 340 in the Duster
OEM MP 440 in the Superbee
Re: what brand of crank are you running? [Re: maxie] #484400
10/01/09 08:46 AM
10/01/09 08:46 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Bryant in the Hemi
Stock in the 383
440source in the convertible
Page 2 of 4 1 2 3 4
