useless 340blocks... rant...
#484276
09/30/09 04:33 PM
09/30/09 04:33 PM
Posts: 2,578 sweden
1Fast340
sweden
just spoke to machineshop where i left a nice 340 block with almost no wear in the originalbores to just have it bored .030over and just straighen out the decks, after boriug it out they found some rustpitting in several bores, low in the bores but still... od thing is that the machineshop said the waterjackets looked fine when they took out the freezeplugs before boring it out and this block has just been living a harmfree life in a warm garage for most of its life not even in a car. i gues it may be a lesson for others about having there blockes checked out to be sure the bores are nice and thick for real and not just hope they are not realy sure what to do now, there is not a lot of 340blocks around and it feels pretty useless to buy another one and hope its better
Re: useless 340blocks... rant...
[Re: 1Fast340]
#484277
09/30/09 04:56 PM
09/30/09 04:56 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If it can't be cleaned up safley by boring you could always have it sleeved.
[Re: 1Fast340]
#484278
09/30/09 04:58 PM
09/30/09 04:58 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Time for a new R3 Replacement 340 block.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: WILD BILL]
#484279
09/30/09 05:00 PM
09/30/09 05:00 PM
Posts: 2,578 sweden
1Fast340
sweden
the sad thing is that since the bores where so nice and clean before boring i have a feeling that these pits come from the waterjackets and that all the bores may be way to thin and that the block may be to week to be safe to use even with sleeves, but i will have a word with them tomorow again and se for myself how bad it looks and what can be done
[Re: PUNK]
#484280
09/30/09 05:07 PM
09/30/09 05:07 PM
Posts: 2,578 sweden
1Fast340
sweden
im afraid your right, but those dont seem to like sollidroller lifters from what i have read in the catalog and thats kind of a dealbreaker for me
my plan was to just have a new block and lower compression to be able to use most of my old parts from the last broken 340 while adding a blower,
this hobby sure gets expensive quickly and feels like i may endup replacing and buying alot more parts than was planed
[Re: 1Fast340]
#484285
10/01/09 01:14 AM
10/01/09 01:14 AM
Posts: 6,139 Melbourne , Australia
LA360
I remember when I was building a 360 years ago, I went through 4 blocks before I found something decent. The one I used was one the machine shop supplied me. I ended up selling that one off too and buying a R3. With almost 40 years of wear and tear; and in many cases, water jackets that never saw an anti corrosive, it's just not worth risking.
If someone ever came out with a reasonably priced factory replacement block, they'd sell like hot cakes. AL....
Alan Jones
[Re: 1Fast340]
#484286
10/01/09 09:02 AM
10/01/09 09:02 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
the sad thing is that since the bores where so nice and clean before boring i have a feeling that these pits come from the waterjackets and that all the bores may be way to thin and that the block may be to week to be safe to use even with sleeves, but i will have a word with them tomorrow again and see for myself how bad it looks and what can be done
Why would you think that ? The sleeve is made of a better material and is uniform in thickness , it's better that the original material the block is cast from. Even if they hit water you can seal the inside of the block and not have any issues .
[Re: PUNK]
#484288
10/01/09 12:03 PM
10/01/09 12:03 PM
PUNK
sorry about the photo. i dont know why it didnt finish loading. This is the R3 block with Indy heads T&D rockers and Manton pushrods mach'd up with the Roller lifters from IMM/OU812 moparts member. This photo if it ever successfully loads is just mach'd up and not final assembled.
[Re: viperblue72]
#484290
10/01/09 08:03 PM
10/01/09 08:03 PM
LA360
Did they Sonic test that area? A machinist friend honed a block one time and the bores wouldn't stay round. Upon closer inspection he noticed a couple of holes in the area he was having trouble with. He put the sonic tester onto it and it was paper thin, so much so that with a tap with a screwdriver, it went through the cylinder wall.
It could be a hole in the casting and nothing a sleeve won't fix, I had a Hemi six that had the same problem. Ran fine for years. AL...
Alan Jones
