Re: Still having alignment issues
[Re: dd340]
#483728
09/29/09 07:57 PM
09/29/09 07:57 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
To get neg camber you want the arm to go in toward the motor.I had a hard time getting my 65 in.I ended up with neg 1 degree caster and about .25 positive camber.That was with the offset bushings.It was at 6 degrees neg before I put the offsets in.That and I did the alingment 3 times my self so I know its right as it can be.It manual steering and handles good where its at.Rocky
Chrysler Firepower
[Re: therocks]
#483729
09/29/09 08:03 PM
09/29/09 08:03 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
Right, so that is why I was thinking if I turn the arrow on the bushing toward the frame it would move the whole arm in a little, I just don't know if that would completely grenade my caster. Which direction did you install the bushings?
[Re: dd340]
#483730
09/29/09 08:03 PM
09/29/09 08:03 PM
RapidRobert
You'd want both sides to end up being the same camber, zero or a skosh neg. With that making the caster different on the one side not sure how it would handle & not sure (with the bushings) if that side can be manipulated to get the caster and the camber equal from side to side with the one side being bent.
[Re: RapidRobert]
#483731
09/29/09 08:05 PM
09/29/09 08:05 PM
dd340
Ottawa, ontario
we brought the left side in to match the final reading on the right side, I was just not happy about the final result. The left side will let us do anything with it, I sure wish the right side was the same.
[Re: dd340]
#483732
09/29/09 08:18 PM
09/29/09 08:18 PM
RapidRobert
I'm thinking the bushings may need to come out & go back in several times to get the right combo so the caster is as close as it can be on each side & close enough for good handling but still keeping the camber dead on (zero or slightly neg) and equal side to side with the camber being by far the most critical.
