how to ID a demon carb? #483465
09/29/09 02:08 PM
09/29/09 02:08 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I have a demon carb I got in a trade a while back and have no use for it but I can't sell it unless I know what it is but there are no number that I see anywhere except 169 on all four throttle plates and it has a vacume secondary pod and electric choke with a single inlet and a crossover tube to fill the other bowl. The secondary venturies look like they are gonna flow less than the primaries never seen that before
How do I tell what the heck this is?
Re: how to ID a demon carb? [Re: HotRodDave] #483466
09/29/09 02:13 PM
09/29/09 02:13 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Contact BG.
Re: how to ID a demon carb? [Re: HotRodDave] #483467
09/29/09 02:14 PM
09/29/09 02:14 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Its a joke. I went through this, you have to figure it out by the parts and design of the carb, there is a page I believe on the demon website. Do a search, I've posted this before, somewhere around june?
Re: how to ID a demon carb? [Re: RemCharger] #483468
09/29/09 05:58 PM
09/29/09 05:58 PM
Kalispell Mt.
Kalispell Mt.
It is a complete joke!
Best as I can tell it is a 750 speed demon.
How do they compare to holleys as far as CFM? I hear they are rated wet flow and holleys are rated dry would this be more or less carb than a say 3310 holley?
Re: how to ID a demon carb? [Re: HotRodDave] #483469
09/29/09 06:24 PM
09/29/09 06:24 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
There is a ton of info on the BG site. You say it's a single fuel inlet carb,the only carbs that match that are Road Demon Jrs. Would that help narrow down the search?
Re: how to ID a demon carb? [Re: goldmember] #483470
09/29/09 06:28 PM
09/29/09 06:28 PM
Kalispell Mt.
Kalispell Mt.
It says on there site that it is a speed demon if it has the red adjustable cap on the vacume secondaries, this one does. Aparently this is a little older of a model even though it looks brand new because it has straight leg secondarie boosters and down leg primaries even though the only ones they have listed have anulars and down legs but no straight legs It has the 7 on the casting for the main body size
This is a very rediculous way of gettin part numbers
Re: how to ID a demon carb? [Re: HotRodDave] #483471
09/29/09 06:37 PM
09/29/09 06:37 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Road Demon Jr. specs is where you need to look .
Re: how to ID a demon carb? [Re: HotRodDave] #483472
09/29/09 06:37 PM
09/29/09 06:37 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
More like "retarded".
Re: how to ID a demon carb? [Re: HotRodDave] #483473
09/30/09 08:42 AM
09/30/09 08:42 AM
NY usa
540challenger Offline
NY usa
Red cap could be added on. No speed demon to my knowledge comes with one inlet and a rod feeding the bowl. Only the road demon JR.
To id the carb there should be numbers stamped on the choke horn.
Re: how to ID a demon carb? [Re: 540challenger] #483474
09/30/09 08:50 AM
09/30/09 08:50 AM
NY usa
NY usa
Re: how to ID a demon carb? [Re: HotRodDave] #483475
09/30/09 09:48 AM
09/30/09 09:48 AM
Dahlonega, GA
TechAtBG Offline
TechAtBG  Offline
Dahlonega, GA
As several have stated already the only single line carburetors we do are the Road Demon Jr's. If it has a red cap somebody has changed the top so they could change the springs out for tuning. 1.69 on all the butterlfies means it is a 725 Road Demon Jr. You should be able to look on top of the main body beside the secondary vent tube and it will have a 7 there and a small dimple.
Technical Support Barry Grant, Inc. www.barrygrant.com
Re: how to ID a demon carb? [Re: TechAtBG] #483476
09/30/09 12:01 PM
09/30/09 12:01 PM
Kalispell Mt.
Kalispell Mt.
Thanks for clearing this up
Got to admit it's a bit confuseing though
Re: how to ID a demon carb? [Re: HotRodDave] #483477
09/30/09 12:02 PM
09/30/09 12:02 PM
Kalispell Mt.
Kalispell Mt.
Any help with this question?
