A body diet ????'s #483386
09/29/09 12:08 PM
09/29/09 12:08 PM
junction city oregon
V
viperblue72 Offline OP
V
Could somebody please break down the weight differences in these areas for an a body?
Stock hood(55lbs.) vs. fiberglass?
stock bumpers vs. fiberglass?
Bench seat(frickin heavy) vs. racing buckets?
Power steering vs. manual.
Also going to a low deck and 4 speed.
low deck vs. smallblock weight?
4spd vs 727 weight?
Re: A body diet ????'s [Re: viperblue72] #483387
09/29/09 12:48 PM
09/29/09 12:48 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
I think my fiberglass hood weighs 15lbs but its AAR so its on the heavier end of fiberglass. You will save alot in my opinion in the bumpers and bumper brackets, probably 30+lbs there. Ive heard theres some savings in the power to manual, but I dont know how much for sure. Im not sure how much my lowdeck and 727 together weigh, but its alot. I can pick up my 318 shortblock by myself, no chance with my lowdeck doing that.
Re: A body diet ????'s [Re: viperblue72] #483388
09/29/09 12:57 PM
09/29/09 12:57 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
Here's a list of the weight related changes I made for my Dart
Weight (11/20/2002) 3040 lbs
Old New Net (Total)
Rear Wheels 30 lbs each 9 lbs each -42 lbs
Front Wheels 42 lbs each 16 lbs each -52 lbs
Frnt Fenders 22 lbs each 11 lbs each -22 lbs
Inner Fenders 15 lbs each Zero -30 lbs
Differential Spool 25 lbs 9 lbs -16 lbs
Front Bumper 23 LBS 3 LBS -20 LBS
Door Beam (R/S) 15 lbs 0 lbs - 15 lbs
Cyl. Heads "- 40 lbs
Weight 9/11/2007 as per IHRA cert. scales 3030 3030
2008
Windshield (-)25 lbs
Front tires (-) 7 lbs
Steering column (-) 15 lbs
Ballast removed (-) 80 lbs
Exhaust system (+) 40 lbs
2961
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: A body diet ????'s [Re: viperblue72] #483389
09/29/09 01:25 PM
09/29/09 01:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
From my 69 Dart, all weighed on the same scales. You're results may vary .
Steel hood 60.1#, AAR 6-Pack bolt on 29.1#
F.bumper w/bumperettes 26#, AAR glass 4.5#
Bumper brackets 13.6#, after lightning 8#
Power steering box/pump/brkts 51.19#, Manual 12.4#
Later model high back bench 80#, Kirkeys 44.3#
11 X 2.5 r/drum 54#, Wilwoods w/parking brk 38#
Iron m/cylinder 15/16" 6.13#, Alum w/res 1.94#
Re: A body diet ????'s [Re: justinp61] #483390
09/29/09 01:59 PM
09/29/09 01:59 PM
V
V
Thanks for the replies guys. Im going from an aluminum headed smallblock to an aluminum headed big block with 4 speed. I am basically trying to make my car weight the same with the new combo. Im figuring around 100lbs. Looks like it should be pretty easy.
Re: A body diet ????'s [Re: viperblue72] #483391
09/29/09 09:53 PM
09/29/09 09:53 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
