Re: help me get my b-1 originals back off the shelf .
[Re: mac56]
#483251
09/29/09 10:42 AM
09/29/09 10:42 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Always better to get the correct pistons.
RIP Monte Smith
[Re: CompWedgeEngines]
#483252
09/29/09 10:47 AM
09/29/09 10:47 AM
Posts: 976 ontario canada
mac56
ontario canada
I will buy the correct ones but just wondering which is prefered flat top and reduce the chamber size or dome.
[Re: Al_Alguire]
#483254
09/29/09 12:13 PM
09/29/09 12:13 PM
mac56
ontario canada
A small dome will make good compression with a b1. It actually will end up being a net 0 or less due to the large valve reliefs required on a B1 head. When you say a lot of compression what do you mean? One mans lot is another mans minimum
I'm running 13.5 right now but maybe more is better
[Re: Brian Hafliger]
#483256
09/29/09 12:36 PM
09/29/09 12:36 PM
mac56
ontario canada
That's fine for alky. You can run more, but it's not neccessary especially since your not looking at a MAX EFFORT build. You'll end up with a dome piston. I don't like milling the heads, you lose deck strength, V/P clearance, manifold fit, etc...
I ran a dome last time but I thought I read on here that most guys cut them for a smaller chamber and flat tops. I'm willing to do all the fitment if it is the best way to go.
#483258
09/29/09 01:42 PM
09/29/09 01:42 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
With out 496 were 14.5/1 compression on gas. The 636 is 15.5/1 on the alchy You will se a world of difference with the b1'S!!! Poor stock block
[Re: Diablo]
#483259
09/29/09 01:45 PM
09/29/09 01:45 PM
mac56
ontario canada
Poor stock block
Yes stock block Doug. That is why I want to keep things conservative.
[Re: Diablo]
#483261
09/29/09 02:42 PM
09/29/09 02:42 PM
mac56
ontario canada
Make sure you fill it, girdle, and alum caps, rods. After i did all that my stock block seemed to hold fine in the 496. 800-850hp range. Im sure you gonna see that or 900hp with the b1's
I be happy with 800 Doug. Did I say that
