help me get my b-1 originals back off the shelf . #483250
09/29/09 10:37 AM
09/29/09 10:37 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I had a good year pulling this year but just feel the cnc eddies aren't cutting it on the 496. I have a b-1 original set up that I haven't run for about 5 years. Just could not afford everything it takes to get them back on. I would like to do that this winter. This does not need to be a max effort mainly due to stock block.
My question is what is the best way to go for pistons. Do you prefer flat tops and cut the heads. I run alcohol so need lots of squeeze.
Thanks Mark
Re: help me get my b-1 originals back off the shelf . [Re: mac56] #483251
09/29/09 10:42 AM
09/29/09 10:42 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Always better to get the correct pistons.
RIP Monte Smith
Re: help me get my b-1 originals back off the shelf . [Re: CompWedgeEngines] #483252
09/29/09 10:47 AM
09/29/09 10:47 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I will buy the correct ones but just wondering which is prefered flat top and reduce the chamber size or dome.
Re: help me get my b-1 originals back off the shelf . [Re: mac56] #483253
09/29/09 10:50 AM
09/29/09 10:50 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A small dome will make good compression with a b1. It actually will end up being a net 0 or less due to the large valve reliefs required on a B1 head. When you say a lot of compression what do you mean? One mans lot is another mans minimum
Re: help me get my b-1 originals back off the shelf . [Re: Al_Alguire] #483254
09/29/09 12:13 PM
09/29/09 12:13 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I'm running 13.5 right now but maybe more is better
Re: help me get my b-1 originals back off the shelf . [Re: mac56] #483255
09/29/09 12:26 PM
09/29/09 12:26 PM
SoCal
Brian Hafliger Offline
SoCal
That's fine for alky. You can run more, but it's not neccessary especially since your not looking at a MAX EFFORT build.
You'll end up with a dome piston. I don't like milling the heads, you lose deck strength, V/P clearance, manifold fit, etc...
Brian Hafliger
Re: help me get my b-1 originals back off the shelf . [Re: Brian Hafliger] #483256
09/29/09 12:36 PM
09/29/09 12:36 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I ran a dome last time but I thought I read on here that most guys cut them for a smaller chamber and flat tops. I'm willing to do all the fitment if it is the best way to go.
Re: help me get my b-1 originals back off the shelf . [Re: mac56] #483257
09/29/09 12:38 PM
09/29/09 12:38 PM
SoCal
SoCal
Not neccessary!!!!!!!!!!!!!!!!!!!!!!!
You do what you want, but you will not see any worthwhile gains by doing that!
Brian Hafliger
Re: help me get my b-1 originals back off the shelf . [Re: Brian Hafliger] #483258
09/29/09 01:42 PM
09/29/09 01:42 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
With out 496 were 14.5/1 compression on gas.
The 636 is 15.5/1 on the alchy
You will se a world of difference with the b1'S!!!
Poor stock block
Re: help me get my b-1 originals back off the shelf . [Re: Diablo] #483259
09/29/09 01:45 PM
09/29/09 01:45 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Poor stock block
Yes stock block Doug. That is why I want to keep things conservative.
Re: help me get my b-1 originals back off the shelf . [Re: mac56] #483260
09/29/09 02:04 PM
09/29/09 02:04 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Make sure you fill it, girdle, and alum caps, rods. After i did all that my stock block seemed to hold fine in the 496. 800-850hp range. Im sure you gonna see that or 900hp with the b1's
Re: help me get my b-1 originals back off the shelf . [Re: Diablo] #483261
09/29/09 02:42 PM
09/29/09 02:42 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I be happy with 800 Doug. Did I say that
Re: help me get my b-1 originals back off the shelf . [Re: mac56] #483262
09/29/09 07:17 PM
09/29/09 07:17 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
as mentioned the reliefs on the b1 pistons have a lot of volume. i doubt you'd loose much strength milling them as they're pretty darn thick in the deck but personally i never liked the idea of cutting heads for CR anyhow (for reasons stated). if you cut them down then it can be a problem if you put them on a larger engine. before you do anything get your numbers together and figure out what can be done. yes the FT piston is best but i wouldn't go hacking up the heads to get there. you really need to do the math first with deck height, piston to head and everything. i forget what the reliefs end up being with a b1 FT but iirc they're "roughly" -12 cc's. to get the CR up on that size engine you probably will end up with a small dome
