GOOD street car shocks? #483208
09/29/09 07:52 AM
09/29/09 07:52 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Anyone with first hand experience that changed to some aftermarket shocks and said WOW?
I have QA1 (single adjustables on the frt) and the long MP shocks (for the SS springs) on the rear. Probably a great strip combo but UGH on the street. Like driving a dump truck.
Re: GOOD street car shocks? [Re: 71TA] #483209
09/29/09 08:20 AM
09/29/09 08:20 AM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
Edelbrock IAS seems to be popular
Re: GOOD street car shocks? [Re: plumebody] #483210
09/29/09 08:39 AM
09/29/09 08:39 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Was just looking at them. $ Ouch though.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: GOOD street car shocks? [Re: 71TA] #483211
09/29/09 11:15 AM
09/29/09 11:15 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
From my real world life experience the edelbrocks are a poor choice for most cars. I used them for a handling hot rod and a 4 door. They porpoise when hot, push the ride height up & keep the suspension bound up. The car will ride like a buckboard wagon. I have street tested & torture tested them [hot laps-road course]and they did nothing to help the ride or the handling.
The hot rod got QA1's and the large chrysler got oem HD service part shocks.
I use the QA1's because it's a real shock, not some high pressure band-aid for other issues like worn springs. The QA1's are adjustable so they can be set to each car and personal taste. If you can't spend $600.00 for QA1's then install oem mopar HD shocks. These can be found still at swap meats, ebay etc at a fair price. I am not talking about nos cuda shocks, I am talking about the mopar service parts HD shocks that were avail from any mopar dealer.
As far as bilsteins and kyb they have been torture tested as well and failed. Konis are ok but pricey and usually not adjustable.
Re: GOOD street car shocks? [Re: ThermoQuad] #483212
09/29/09 11:20 AM
09/29/09 11:20 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I've always been pleased with the KYB GasAdjust shocks.
A lot of it depends on your budget, too.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: GOOD street car shocks? [Re: Fury Fan] #483213
09/29/09 12:09 PM
09/29/09 12:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you like the ride quality of a Massey Ferguson tractor then you'll like KYB's...
I guess with a Sea Body they weigh enough that the shocks may work. on an E body you might as well install ridgid struts in place of the shocks... Like Tom said Std HD shocks or step up to Koni's..
Re: GOOD street car shocks? [Re: ThermoQuad] #483214
09/29/09 12:17 PM
09/29/09 12:17 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks Tom. I have QA1 Stocker Star drag shocks on the frt I could flip.
And I did look into the QA1 DOUBLE adjustable shocks. Pricey. Is that $329 a PAIR?
Re: GOOD street car shocks? [Re: 71TA] #483215
09/29/09 12:30 PM
09/29/09 12:30 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I have had the IAS shocks on the GTX for a couple years now and have no issues with them. They ride just fine. I have .96 bars and HD springs with an extra main leaf added, sway bar up front but nothing in the back. They handle pretty well on off ramps and are not harsh.
Ken
Re: GOOD street car shocks? [Re: 71TA] #483216
09/29/09 12:37 PM
09/29/09 12:37 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That's your problem. Get 6 leaf ESPO springs and QA1 adjustable shocks on the rear.
Re: GOOD street car shocks? [Re: Lefty] #483217
09/29/09 12:56 PM
09/29/09 12:56 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
QA1 are twin tube shocks which are steps below a high pressure gas monotube. Monotubes tend to ride much better as well.
The bilstein is a monotube design as well as the edelbrock. I agree the edelbrocks have some weird valving, but I wonder if the failure was from the one size fits all, as were the correct lenght (more likely).
The high pressure gas just helps the oil to stay stable during the heat of the action.
Re: GOOD street car shocks? [Re: Lefty] #483218
09/29/09 12:58 PM
09/29/09 12:58 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have seen many claims that stock Monroe shocks are one of the best kept secrets out there.. Price is right and the ride is smooth. Installed a set of monroes on the front of my sons 95 Jaguar.. Made a ton of difference for $59.....
I have KYB's on my 67 B body and they seem fine..I wanted a stiffer shock and figured my car was fairly heavy...
Re: GOOD street car shocks? [Re: 71TA] #483219
09/29/09 05:25 PM
09/29/09 05:25 PM
Southern CA
Colin Frolick Offline
Southern CA
Bilsteins...
http://www.racecardynamics.com/classics/indexhr/products/stock%20applications/musclecar.htm
Firm Feel is a retailer for RCD. I got these on my big Imperial lately and they are amazing. before it had kyb's on the front and some bastardized single-adjustable qa1's off my pontiac tempest on the back. the qa1's are too stiff, even on a big heavy mopar, even on their lowest settings. the kyb's on the front were overworked. now i hustle around at speed with ease.
Re: GOOD street car shocks? [Re: Colin Frolick] #483220
09/29/09 05:38 PM
09/29/09 05:38 PM
Lefty Offline
Lefty  Offline
Bilsteins...
It's great to hear Bilsteins are available front and rear on our Mopars. They are great shocks. They were a huge improvement on my Cummins Ram.
I have to disagree about the QA1's. I have the single adjustable (rebound) on my 66 Coronet and they work great. I'm set on #4 in front and #3 in the back. Maybe they don't work well on really soft springs?
Re: GOOD street car shocks? [Re: Lefty] #483221
09/29/09 08:35 PM
09/29/09 08:35 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I redid my suspension this summer and put on Monroes all the way around. My car is your basic street/strip car not an autocrosser, and I am happy with the ride quality. Got my shocks thru Rockauto. I am running SS springs in the rear also, so go for 71 imperial shocks for the rear as they are longer.
