Re: Help 60fts all over
[Re: Smoparmike]
#482324
09/28/09 11:33 AM
09/28/09 11:33 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
I would get rid of the radials first, they do not always work good on bad tracks Your 60 ft. times are good when the car hooks and stays hooked up. Many people fight the Cal Tracs and never get them to work as good as your car is doing now The bigger tire size will help also, especially on marginal tracks.
[Re: Smoparmike]
#482328
09/28/09 11:44 AM
09/28/09 11:44 AM
Posts: 535 Ohio
racerAL
Ohio
i would say it's a combinatin of poor track prep and radial slicks. i would consider new slicks...from what i've read the radials have a tendancy to be inconsistant on marginal tracks..i had the same issue as you are describing(although not radials)and i put a new set of slicks on it,and it went right back to normal, only moving around between .002 to .008 on the 60 ft.for the 7 passes i put on it @ norwalk for the cc race.
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: Smoparmike]
#482333
09/28/09 12:25 PM
09/28/09 12:25 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I am running a Hoosier 30 x 9 radial slick at the track on my 63. I have stock suspension with SS springs. I will say when the track is not good I dont always hook good. But when the track is working they hook great. I have my best 60 on them and they are also faster then the bias tires I did run. Even when I dont hook good I still run faster then the bias tires did. I like them but I am not a class racer as I just run my 63 at T & T's a couple times a year. Ron
