rearend width question
#482257
09/28/09 09:15 AM
09/28/09 09:15 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
What's the standard width on a '68-'70 B body rearend? And where do you normally take the measurement from?...flange? backing plate? axle flange? Thanks, CHIP
Re: rearend width question
[Re: an8sec70cuda]
#482258
09/28/09 09:30 AM
09/28/09 09:30 AM
Posts: 6,295 U.S.
moparniac
U.S.
55" housing flange to flange and 44"'s center to center on the perches.... looking for bigger meats chip... You can get the 315's in there I went a little narrower when I put the dana in though!
Mopar Performance
[Re: an8sec70cuda]
#482259
09/28/09 09:34 AM
09/28/09 09:34 AM
Posts: 10,022 MN
JERICOGTX
MN
Cut it down to 46" and you can fit 12" rims with 3.5 BS real nice! Working the RR again Chip?
Jeff
69 GTX
68 Road Runner
[Re: moparniac]
#482261
09/28/09 10:08 AM
09/28/09 10:08 AM
an8sec70cuda
Thanks for the info Wedgie and Jerico! Yes, I am slowly putting things together for the road runner. Need to get the 9" housing cut and the ends welded on. Already have a complete Moser nodular centersection for it. Motor is ready to go, but need to build another transmission since the one originally intended for this car wound up in the 'cuda when I blew it up last year. Has a long way to go, but I'm in no hurry. Just gonna make a fun ride out of it, maybe try to run it on E-85. CHIP
[Re: Cab_Burge]
#482263
09/28/09 01:08 PM
09/28/09 01:08 PM
an8sec70cuda
I am using Mopar housing ends on a Ford 9", so I'll be fine with the measurements from the housing flange. CHIP
[Re: an8sec70cuda]
#482264
09/28/09 01:14 PM
09/28/09 01:14 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
The distance between the outer edge of the axle bearings and the axle flange vary from manufactuter, Mopars A body 8 3/4 distance is different (shorter,narrower brakes) than the B,C and E body are. I don't have a clue on how many different distances Ford used between the axle flanges and the bearings on there production vehicles
