Re: MSD 6A problems - initial fires then won't keep running
[Re: 69CopperCoronet]
#482135
09/28/09 01:07 AM
09/28/09 01:07 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
the wires that were on the ballast resistor need to be connected together with the orange wire from the msd...
you are getting voltage from one of the wires for the start circuit but not the run circuit...that is why the two wire need to be connected together...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: GoodysGotaCuda]
#482138
09/28/09 01:30 AM
09/28/09 01:30 AM
Posts: 249 Kahleefahwniah
69CopperCoronet
Kahleefahwniah
goodys- how should i wire this working with the factory wiring?
#482140
09/28/09 11:47 AM
09/28/09 11:47 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
The noise is hit or miss...my 70 Charger had a humming noise but I asked the MSD rep at the local speed shop one day and he said that some boxes do that and others dont. The one on my 70 dart was quiet, the 69 hums every now and then but its been like that for 7 years and never had an issue.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#482141
09/28/09 12:22 PM
09/28/09 12:22 PM
70AARcuda
las vegas
the msd 6 does not use the factory ballast resistor..
Tony
