Re: to much lift
[Re: rowin4]
#482118
09/28/09 01:31 AM
09/28/09 01:31 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
I would try stiffer front shock settings and I would coreect the rear spring shackle angle, it may be adding to the problem instead of running out of RPM as you said. Most of the cars that I have driven and help on that did wheelies would set the front tires down slowly or gently enough to not smash the oil pan, one exception was a car that had the rear shackle angle almost straight up and down when sitting at static ride hieght with no preload on the suspension like you get when foot braking in 1st gear. Tha car would porpoise up and down going forward and try to hook and pull the front tires off and then porpoise and spin the rear tires and try to hook and porpoise again You can tie the front in down also which may or may not help, it works on some cars and not on others How about the lower control arm bumpers, what shape and size are they? I have also raised the front end ride hieght to limit the amount of hieght on the wheelies, less travel = less hiegth
