727 or powerglide #481979
09/27/09 10:02 PM
09/27/09 10:02 PM
duster408 Offline OP
My friend has a 73 Dart Sport with a 650HP 440. It will not stay up on the tires at the launch. It hits the tires and goes 3 feet and spins. It currently has a 456 rear gear, powerglide and 3600 stall converter. The car weighs 2900 lbs. Any thoughts on more rear gear, more stall, or 727? Thanks.
Post deleted by Defbob [Re: duster408] #481980
09/27/09 10:06 PM
09/27/09 10:06 PM
Re: 727 or powerglide #481981
09/27/09 10:25 PM
09/27/09 10:25 PM
ladder bar
Re: 727 or powerglide [Re: duster408] #481982
09/27/09 10:30 PM
09/27/09 10:30 PM
ky
68roadrunner Offline
ky
ladder bar
coil over or floater and leaf spring?
Re: 727 or powerglide [Re: 68roadrunner] #481983
09/27/09 10:34 PM
09/27/09 10:34 PM
coil over. Also has adjustable front shocks.
Re: 727 or powerglide [Re: duster408] #481984
09/27/09 10:59 PM
09/27/09 10:59 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I agree, chassis might require changes, but,... the convertor could use more stall if you ask me.
Re: 727 or powerglide [Re: 540dust] #481985
09/27/09 11:11 PM
09/27/09 11:11 PM
ky
ky
and if it is front end heavy, may have to go looser on the front shocks.
Re: 727 or powerglide [Re: 68roadrunner] #481986
09/28/09 12:08 AM
09/28/09 12:08 AM
ladder bars are in the middle hole. shocks are on 4 clicks out of 6
Post deleted by Defbob [Re: duster408] #481987
09/28/09 04:02 AM
09/28/09 04:02 AM
Re: 727 or powerglide #481988
09/28/09 09:12 AM
09/28/09 09:12 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Not a trans problem.i think if you put a 727 in it than you will have more problems.its the chassic or suspension
Re: 727 or powerglide [Re: duster408] #481989
09/28/09 10:11 AM
09/28/09 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know what shocks you have but try tightening
them up all the way... the car is doing what we call
po-going or porpoising.... also you might try the low
hole.... it hits the tire softer but holds the hit longer
Re: 727 or powerglide [Re: MR_P_BODY] #481990
09/28/09 03:18 PM
09/28/09 03:18 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Nobody has mentioned, that the frontend could be so soft, that it is stretching the front out too quickly, bottoming out and unloading the tires.
Monte
