Freeze plug blows out @ 105 mph #481136
09/27/09 02:03 PM
09/27/09 02:03 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
I was at arm drop live in Memphis Friday. It had rained all week and the track was green so I let a few cars go ahead of me to down a little rubber.The routine was the same as always, 160 degrees, roll through the water, 2nd to 3rd for a 3 second burnout, roll in,stage,launch, it only had a 1.45 60 foot,ran a 6.63 @ 102 then I heard a pop and the front end dropped. I thought a ball joint broke so I just coasted on through the lights.Then I saw water coming up through the edge of the hood so I cut it off.The freeze plug behind the drivers side motor mount blew out. I think that is what saved me as the motor mount dispersed the water as it came out. The freeze plug is brass but is very shallow like a 1/8 shoulder.They were already installed in the block when I bought the car 4 years ago. I will be putting in the deep ones with a 1/4 inch shoulder. I am very thankful to have not hit the wall Any ideas what might have caused it to come out? Block flex or just the shallow shoulder combined with the narrow block shoulder or something else?
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Freeze plug blows out @ 105 mph [Re: 67HEMI] #481137
09/27/09 03:06 PM
09/27/09 03:06 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
...The freeze plug behind the drivers side motor mount blew out... Any ideas what might have caused it to come out? Block flex or just the shallow shoulder combined with the narrow block shoulder or something else?
Are you using the motor mounts? or a plate? If mounts it probably is due to the flex.
Glad it didn't get ugly!
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Freeze plug blows out @ 105 mph [Re: BBLM23] #481138
09/27/09 03:56 PM
09/27/09 03:56 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Had the same problem with mine last season, only
I lost the same 1 twice, never could see, or figure out why this problem started to occur, I had ran the block several season before, and never any problems ,mine was in the middle hole on the pass side of the block, thought it might have been brass plug related, so I changed brands of plugs, and had it happen again, after the second time I used one of those rubber squeeze type, and have had no more problems with it since, knock on wood, have never figured out why this just started happening, but as you know it is not any fun when it happens, I almost stuffed mine in the wall the first time, but luckily it recovered before any contact, but the car had an awful smell inside for a while .
Be extra careful with it if you go with another brass plug, it could happen again, which I hope you don't have any problems with it, I though when mine did it the first time it was just one of those fluke deals, but after the 2nd time, that theory was out the window.
Good luck
Re: Freeze plug blows out @ 105 mph [Re: 65racer] #481139
09/27/09 04:05 PM
09/27/09 04:05 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
did you have antifreeze in the car..... rich is a stickler about that! glad everything was okay...... Im so glad my new block has screw in ones..... that happened to me one time going down the street! Try this below!
Mopar Performance
Re: Freeze plug blows out @ 105 mph [Re: moparniac] #481140
09/27/09 04:38 PM
09/27/09 04:38 PM
67HEMI Offline OP
67HEMI  Offline OP
No all I had was water and water wetter in it. With antifreeze it might have gotten real ugly!!I like the CHINESE freeze plug picture That is a good idea with the screws or I thought about tapping the block and using screw in type.
Re: Freeze plug blows out @ 105 mph [Re: BBLM23] #481141
09/27/09 04:42 PM
09/27/09 04:42 PM
67HEMI Offline OP
67HEMI  Offline OP
I am using solid steel mounts.
Re: Freeze plug blows out @ 105 mph [Re: moparniac] #481142
09/27/09 05:19 PM
09/27/09 05:19 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I have had two freezeplugs come out. One was when I welded a fitting in the plug and it blew out at about 160MPH. Nothing exciting just a big geizer in the video.
The second time was a new engine. I had made the mistake of using a crank with a rod that was close in weight and a piston close in weight to what was run before. In too big a hurry to get balanced. The PS front plug came out. It was late winter and the water was green. When the water is green, you know the deal(antifreeze) it is slick and I bruised the car. Fixed the car put a new plug in and shot it out again at the next race with no incidents.
I removed the engine and used stainless button head screws very similar to this picture to secure the plugs. In my case the plug was being shook out of the block as the spinning assembly was 300 grams out of balance.
Chock this up for another lesson learned.
Leon
Re: Freeze plug blows out @ 105 mph [Re: moparniac] #481143
09/27/09 05:20 PM
09/27/09 05:20 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
CHINA, that says it all.
Re: Freeze plug blows out @ 105 mph [Re: Shaker223] #481144
09/27/09 05:51 PM
09/27/09 05:51 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I have been fighting this same problem for a long time, a member on here said that detonation will shake them out, I'm thinking that might be the case.
Re: Freeze plug blows out @ 105 mph [Re: cgall] #481145
09/27/09 10:04 PM
09/27/09 10:04 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Yep, I have first hand experience with this. The plug falling out is symptom of problem.
8.30's @3400 lbs
Re: Freeze plug blows out @ 105 mph [Re: Mike Swann] #481146
09/27/09 10:54 PM
09/27/09 10:54 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
A friend crashed his Firebird this summer, because of a freeze plug coming out. We were spraying it for the first time this year and I put a little more jst in then before, well it took off and was on a low 9 sec pass, the plug came out, went left, then right into the wall. we've already fixed it, but I'm nervous to take it out again.
Re: Freeze plug blows out @ 105 mph [Re: moparniac] #481147
09/27/09 11:20 PM
09/27/09 11:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I know thats better then nothing, but is it enough? How about a captive plate using the same 3 tapped screw holes? I mean how often do the freeze plugs ever need to be taken out? Are they really freeze plugs anymore anyhow?
