Serpentine belt squeak question. #481110
09/27/09 01:08 PM
09/27/09 01:08 PM
Iowa
3
318Bruiser Offline OP
Iowa
Long story short. I had a continuous squeal with my old belt, tried some wd40 and it went away for a bit. Cleaned up the pulley's and changed the belt. Squeal was back from the start but was only once every rotation. I changed the idler and tensioner pulley and same thing, they were bad anyway. I cleaned the old belt with light soap and water and it was quiet for about 5 min. WD40 again and it went away. I hand rotated all the accessories and none of them made the noise. Am I safe to assume that it is a belt issue and even the new one is bad? How can I determine if the tensioner itself is bad without replacing or using a puller tester? Thanks ahead of time for your opinions.
Re: Serpentine belt squeak question. [Re: 318Bruiser] #481111
09/27/09 01:46 PM
09/27/09 01:46 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Pour a little water on belt with mtr running,belt will usually stop squeaking. I had the same prob. I think it started after a water pump change. I tried cheap belts,NAPA belts,they all squeaked. Finally bought a Good year Gatoback belt,no squeak since. It was about the same price as NAPA.
Re: Serpentine belt squeak question. [Re: 318Bruiser] #481112
09/27/09 03:43 PM
09/27/09 03:43 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Odds are your belt and/or pulleys are glazed. Scuff the glaze off all the pulleys with something like a coarse scotchbrite pad, always worked for me.
I wont use WD40 on belts, it has petrolium distilates and that isnt good for them. Besides you want to clean the surface to stop slipping, not lube it. There is a "belt dressing" made but IMO its a short term solution not a fix.
Re: Serpentine belt squeak question. [Re: nomore65BelvJim] #481113
09/27/09 03:54 PM
09/27/09 03:54 PM
Cornfields of Illinois
RoboGeek Offline
RoboGeek  Offline
same issue here. After an alternator locked up, I replaced it, using the old belt that was only a month old. It had an irritating chirp-chirp-chirp that I attributed to a glazed spot on the belt. Replaced the new belt with another new belt and it was perfect for a few hundred miles.
Tensioner is good, so I'm going to try another belt - not the $8.95 Autozone belt thats on it now
Re: Serpentine belt squeak question. [Re: RoboGeek] #481114
09/27/09 05:08 PM
09/27/09 05:08 PM
Iowa
3
Iowa
When I put the new belt on, I did scuff up all the pulley's and cleaned off all of the WD40. I just looked at the new belt and it does seem to be glazed a bit. Thanks.
Re: Serpentine belt squeak question. [Re: 318Bruiser] #481115
09/27/09 06:04 PM
09/27/09 06:04 PM
central PA
mopartial Offline
mopartial  Offline
central PA
Mine chirps when I hit the gas/upshift (its a stick). If I drive it like a granny it wont do it. Tensioner is new, tried 2 new belts...still a nagging problem.
Tried belt dressing spray then somebody told me that is for V-belt, not serp...
If it aint broke, dont break it.
Re: Serpentine belt squeak question. [Re: mopartial] #481116
09/27/09 07:58 PM
09/27/09 07:58 PM
Tennessee
classof65 Offline
classof65  Offline
Tennessee
Look closely at your power steering bracket if the engine in question is of a Magnum variety. IT MAY BE BENT.. Sounds odd, yes, but over and over again I have seen this. Since I work in the parts business I see silly things and this is one that even Ma Mopar knows about. If you have had an idler lock up, a water pump go, an AC Compressor lock up, or any other situation that stopped the belt DEAD in it's tracks, LOOK at the alignment of the P.S. Pulley. How this happens is beyond me, but it does.
Peace, Rev. Mopar
Re: Serpentine belt squeak question. [Re: classof65] #481117
09/27/09 08:16 PM
09/27/09 08:16 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Goodyear Gatorback
Re: Serpentine belt squeak question. [Re: mopartial] #481118
09/27/09 11:54 PM
09/27/09 11:54 PM
MNobody Offline
MNobody  Offline
The one on my van is chirping and squealing too, a buddy told me to put Dialectric grease on my finger and wipe it across the rib's of the belt. Worked for a couple days then the squeal is back. I'll be watching for the fix cause i've tried cleaning the belt and pulley's and belt dressing with no good results.
Re: Serpentine belt squeak question. [Re: MNobody] #481119
09/28/09 03:50 AM
09/28/09 03:50 AM
Iowa
3
Iowa
It is actually on a 92 s10 blazer. All of the pulleys are in line but the power steering one wobbles just a tad bit. I thought that could be an issue but turning the steering wheel back and forth does not make it squeal louder. This is annoying for me of course but I would rather have no exhaust then have this thing chirp as loud as it does when I am next to someone, LOL.
Re: Serpentine belt squeak question. [Re: mopartial] #481120
09/28/09 08:52 AM
09/28/09 08:52 AM
MA
Mass_Mopar Offline
Mass_Mopar  Offline
MA
My girlfriend's neon does this too, squeals when you're past 1/4 throttle. Hasn't annoyed me enough yet to do anything about it though Guess I'll try replacing the belt and scuffing up the pulleys
Re: Serpentine belt squeak question. [Re: 318Bruiser] #481121
09/28/09 08:59 AM
09/28/09 08:59 AM
PA
70Duster Offline
70Duster  Offline
PA
I agree with pushbutton on this. I had the same issue with the cheaper belts and after putting on the Goodyear Gatorback, it never squeaked again.
Re: Serpentine belt squeak question. [Re: 70Duster] #481122
09/30/09 09:29 AM
09/30/09 09:29 AM
MA
Mass_Mopar Offline
Mass_Mopar  Offline
MA
Where did everyone buy their Gatorback? I'll take one for a 98 Neon...
Re: Serpentine belt squeak question. [Re: Mass_Mopar] #481123
09/30/09 11:49 AM
09/30/09 11:49 AM
Clinton Twp. Michigan
coronet1966d Offline
auto zone, dayco poly cog is just as good as a gatorback and they are sold at advance auto
Re: Serpentine belt squeak question. [Re: Mass_Mopar] #481124
09/30/09 11:52 AM
09/30/09 11:52 AM
PA
70Duster Offline
70Duster  Offline
PA
I got the Gatorback at Autozone.
Re: Serpentine belt squeak question. [Re: 70Duster] #481125
09/30/09 12:07 PM
09/30/09 12:07 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Waterpump or power steering shaft runout can also cause belt chirping/squeak.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
