What's the trick to keep flex plate bolts tight? #480998
09/27/09 10:28 AM
09/27/09 10:28 AM
southwest Alabama
challenger73400 Offline OP
southwest Alabama
The first time I put the motor (470) in I made 70+ passes and the flex plate came loose. I bought a new flex plate (didn't want to take a chance of it coming loose again due to using the old one) and new ARP bolts, cleaned the treads so the lock tight will grip. I used a torque wrench to install and torqued to the arp specs. I went to the track twice and now there loose again.
One guy at the track said he uses chevy bolts, they have some locking head on them I quess like a star locking washer.
What bolts do I need or is there a trick most mopar people use I haven't heard about yet? Thanks.
Post deleted by Defbob [Re: challenger73400] #480999
09/27/09 10:34 AM
09/27/09 10:34 AM
Re: What's the trick to keep flex plate bolts tight? #481000
09/27/09 10:37 AM
09/27/09 10:37 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i have found that if i ignor the torque specs and just tighten the holy crap out of them they stay tight,and i use the red loctite.
Post deleted by Defbob [Re: bonefish] #481001
09/27/09 11:15 AM
09/27/09 11:15 AM
Re: What's the trick to keep flex plate bolts tight? #481002
09/27/09 11:19 AM
09/27/09 11:19 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i use blue loc-tite and never have a problem.
Re: What's the trick to keep flex plate bolts tight? #481003
09/27/09 11:20 AM
09/27/09 11:20 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
red loc-tite stock bolts beat them tight..if they come loose. something else is wrong..
Re: What's the trick to keep flex plate bolts tight? [Re: VernMotor] #481004
09/27/09 11:42 AM
09/27/09 11:42 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have a jw adapter and 6 bolts. red loctite here also no issues at all.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What's the trick to keep flex plate bolts tight? [Re: bigtimeauto] #481005
09/27/09 01:21 PM
09/27/09 01:21 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
How much do you guys torque them to.... ARP stuff.....
Mopar Performance
Re: What's the trick to keep flex plate bolts tight? [Re: bonefish] #481006
09/27/09 01:29 PM
09/27/09 01:29 PM
OH, USA
Torred Offline
Torred  Offline
OH, USA
Re: What's the trick to keep flex plate bolts tight? [Re: Torred] #481007
09/27/09 01:37 PM
09/27/09 01:37 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Red Lock Tite and a air impact= no problems
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: What's the trick to keep flex plate bolts tight? [Re: Torred] #481008
09/27/09 01:38 PM
09/27/09 01:38 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Same here.. beat them tight with a hammer and a wrench..been doing that for 25 years.. I know we will have all them guys coming on here O-no thats not right! boo hoo..It works.. beside geting a torque wrench up there is a real pain too.
Re: What's the trick to keep flex plate bolts tight? [Re: VernMotor] #481009
09/27/09 01:57 PM
09/27/09 01:57 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Dont want to be a downer but you might have a cracked crank shaft. I couldn't keep mine tight on the new engine. Ended up having a cracked crank. I didn't want to believe what some were telling me but i took the crank out and had it tested. Didn't want to loose my entire 636ci engine due to someone lying about the crank being checked. Better safe than sorry. I acted safe and probably saved my engine from turning into a BOMB!
Re: What's the trick to keep flex plate bolts tight? #481010
09/27/09 03:16 PM
09/27/09 03:16 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Try red Loctite.
X2
Re: What's the trick to keep flex plate bolts tight? [Re: B1KILLER] #481011
09/27/09 03:27 PM
09/27/09 03:27 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
What balancer is on engine?
Re: What's the trick to keep flex plate bolts tight? [Re: moparniac] #481012
09/27/09 03:35 PM
09/27/09 03:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What ever a 1/2 drive Impact will hit too several seconds after the socket stops moving, plus some red loctite as mentioned.
Re: What's the trick to keep flex plate bolts tight? [Re: Diablo] #481013
09/27/09 03:47 PM
09/27/09 03:47 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Doug I never read that was what ended up being your problem. Sorry to hear that. I hope with all the issues you have had this season getting that monster running your are laying a smack down on those chevies.
Re: What's the trick to keep flex plate bolts tight? [Re: challenger73400] #481014
09/27/09 05:15 PM
09/27/09 05:15 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I just had the same problem with my converter bolts becoming loose and i used red loctite and they have a lock washer on them as well.I was told to retorque them after a couple passes which really doesn't make much sense to me especially with the loctite in there.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: What's the trick to keep flex plate bolts tight? [Re: W5DART66] #481015
09/27/09 05:44 PM
09/27/09 05:44 PM
southwest Alabama
southwest Alabama
440 source SFI balancer. No unusual vibrations.
Thanks guys, I'll put red lock tight and some bowinkle on the bolts!
BTW. how does a cracked crank cause the flex plate bolts to come loose? Added vibration?
Re: What's the trick to keep flex plate bolts tight? [Re: challenger73400] #481016
09/27/09 06:13 PM
09/27/09 06:13 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
At a certain RPM there will be a harmonic vibration and just spin bolts and nuts out. On the Dyno i could actually watch the valve cover nuts come off when going up the RPM range. We didn't have an idea of the crank being cracked at that time.
Mark (Mac56): We ended up running the 496 again for most of the summer. For the two runs with the 636 we were pretty happy. We know we will be in the top 3-4 trucks for hp next year. There were three other GM boys that came in with 600ci 1000-1100hp engines and the 496 had a hard time trying to run with them on the clay tracks. But it did well for what it is. Next year they will have a mopar to watch for
Re: What's the trick to keep flex plate bolts tight? [Re: Diablo] #481017
09/27/09 07:02 PM
09/27/09 07:02 PM
UK
602heavy Offline
602heavy  Offline
UK
Great idea using a torque wrench , how do you get it in there with the sump on? , or am i missing something ........ ring spanner doubled up is all that fit in there.
