Re: 4.7 liter in A-body?
[Re: pyrogen]
#480594
09/26/09 09:32 PM
09/26/09 09:32 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
I have heard bad things about 4.7 motors. cylinder head issues causing the whole motor to go bad. I would stick with a 5.9 or a 5.2 motor.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: cantspel]
#480596
09/26/09 10:09 PM
09/26/09 10:09 PM
Posts: 17 N.E. Texas
pyrogen
N.E. Texas
I am still researching which manual transmissions were used behind that engine. The Getrag 6spd sounds good in theory, but it will probably come down to availability.
2001 Dodge Dakota R/T reg cab - slow
1970 Dodge Dart Swinger /6 auto - slower
1988 Toyota Pick-up 4wd - slowest
[Re: cantspel]
#480601
09/27/09 12:06 AM
09/27/09 12:06 AM
pyrogen
N.E. Texas
How much of the 4.7l failures are improper maintenance vs poor design/parts
[Re: Chris2581]
#480604
09/27/09 08:45 AM
09/27/09 08:45 AM
blk00rt
Michigan Troll
I have had a couple coworkers who had dakotas with this engine. Both of them had a cylinder head issue that caused the whole side of the engine to be replaced. Dealer did not tell them exactly what happened because it was under warranty, but said they had seen it before there. Both engines had less than 20k on the clock.
[Re: blk00rt]
#480605
09/27/09 09:18 AM
09/27/09 09:18 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
FWIW..I have 127K on my 4.7 in my Ram quad cab,and it still gets 21.9 unloaded on the highway.That being said,I still think this makes a great swap.The 4.7 makes great power and is easy to maintain.The only problem I see would maybe the oil filter hitting the K-frame area.I'm actually surprised that the 4.7 isn't being swapped into older Jeeps like CJ-7's,that would be a heck of a 4x4.
[Re: Chris2581]
#480606
09/27/09 09:38 AM
09/27/09 09:38 AM
pyrogen
N.E. Texas
ok. so here is a list of things that might cause a problem:
oil filter oil pan motor mounts trans mount exhaust accessory drives
most of these things can probably be avoided with engine placement, a remote filter can take care of the filter hitting anything, the main question is the oil pan and mounts. They were only put in trucks so there are no center sump pans. I'll work on getting dimensions compared to an LA to see where I am at.
Anything else that I am not thinking of?
[Re: pyrogen]
#480607
09/27/09 10:54 AM
09/27/09 10:54 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
the only issue that I know of that the 4.7s had, was a poor PCV design or lack of...I don't remember which, and the motors would sludge up from moisture in the crankcase. but that was fixed with a TSB/recall early on. any of the newer motors will be fine.
you guys complaining about poor mileage? I'd hate to see what you consider GOOD! my 5500lb (empty) 05 Durango (the bigger, newer style) with a 4.7, auto tranny, and 3.92 gears would get up and go pretty darn good, yet was capable of about 20 MPG on the highway at 70 MPH! I'm sure that in a more aerodynamic vehicle that's 2,000 lbs lighter, 25-27 would not be a problem.
for a V8, I'd say that sounds pretty good!
If I was going to do this swap, I would hunt for a wrecked Dakota that had the 4.7, and a 5spd manual. swap the whole thing in--to include engine computer and wire harness, then put a 3.90 or 4.10 gearset in your axle and go have fun!
with the OD of the 5 spd, you'll still be able to keep the RPM down on the highway, no need for a 3.21 gear, you'd be idling down the freeway!
(my Durango, with 3.92s and the 5spd automatic would do 75mph turning 2200 rpm.)
**Photobucket sucks**
[Re: DaytonaTurbo]
#480609
09/27/09 06:35 PM
09/27/09 06:35 PM
pyrogen
N.E. Texas
yes finding a total loss dakota or ram with the manual is my plan, but I am also considering the possibility that I might have to piece this combo together, which will be "fun" because for some reason no one wants to drive a vehicle with a manual trans anymore making them kind of rare.
Correct me if I am wrong, but in 2000-2003 Dodge trucks were offered with both the 4.7 and the 5.9, therefore the mounts will be different but should mount in the same location?
If this is correct, I figure that if I can come up with a salvaged truck then I should be able to fab a hybrid truck/ A-body trans x member that uses the factory truck mount and find a way to use the factory truck motor mounts as well for maintenance simplicity. Leaving me with just routing the exhaust, coming up with a drive shaft, and the oil pan.
I have a lot of research to do as it seems I am breaking new ground here.
[Re: pyrogen]
#480610
09/27/09 10:24 PM
09/27/09 10:24 PM
Posts: 4,323 NY NY
340duster340
NY NY
i dont want to talk you out of the 4.7L, but what what about a chevy 350? seriously, good luck with the project and if it has not already been mentioned, check the trans tunnel clearance...not a whole lot of room where the t-bar x member is.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#480611
09/27/09 11:23 PM
09/27/09 11:23 PM
DaytonaTurbo
Manitoba, Canada
And this is the part I need to stress. I know others putting truck a518 auto transmissions in their a bodies have needed to do floor tunnel surgury as well as cutting out and fabricating their own center section of the torsion bar cross member. And from what I hear the truck 5-sp's are only larger than their auto trans counterparts. So I hope you have good fab skills and aren't afraid to do some splicing and dicing on your car. This is why I suggested looking into the o/d 833 4sp manual trans out of the late 70's mopars. At least you can get the trans, linkages, mounts, everything and bolt that trans right up as the factory intended without having to hack anything. That saves the modding for just the motor mounts.
