Drilling return lines in cell? #480420
09/26/09 07:21 PM
09/26/09 07:21 PM
KY
juicedcuda Offline OP
KY
I need to add two return lines in my polyethylene cell. One for the bypass on the pump and another from the nitrous regs. Where is the best place to drill the fittings in at? Any techniques to keep junk out of the cell?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Drilling return lines in cell? [Re: juicedcuda] #480421
09/26/09 07:27 PM
09/26/09 07:27 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I don't know if it matters where you put them, but when I did mine I stuck my hand in the cell (plastic)with a rag and drilled through, and caught debris in rag. If it's aluminum it's a different story.
Re: Drilling return lines in cell? [Re: Lil Wedge] #480422
09/26/09 07:47 PM
09/26/09 07:47 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Remove the filler neck hardware,remove the foam,use a holesaw.Clean all the crap out and reinstall.Drill your return hole as far away from the pickup sump as you can.
Re: Drilling return lines in cell? [Re: B G Racing] #480423
09/26/09 08:02 PM
09/26/09 08:02 PM
KY
KY
Sounds good. Thanks guys.
Re: Drilling return lines in cell? [Re: juicedcuda] #480424
09/26/09 08:21 PM
09/26/09 08:21 PM
dont use a hole saw, use a step drill bit, going in as tight as possible so you get a snug fit.
you can go in a little at a time to get proper fitment.
Re: Drilling return lines in cell? #480425
09/26/09 08:27 PM
09/26/09 08:27 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Drill bits and step drills tend to grab,wooble and tear at the plastic fuel cells,especially when your trying to make a large hole for a #8 balkhead fitting.IF your hole is a little loose just use teflon washers which are recommended for both sides of the fitting.
Re: Drilling return lines in cell? [Re: B G Racing] #480426
09/26/09 08:32 PM
09/26/09 08:32 PM
sorry but i disagree totally. using a step bit goes in like butter and bulhead goes in nice and tight with a teflon washer.
the jaz bulkheads are the best by far.
a hole saw gives you a ragged edge and i havent liked the holesaw fit, it seems to be too loose.
Re: Drilling return lines in cell? [Re: juicedcuda] #480427
09/26/09 11:13 PM
09/26/09 11:13 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I added return lines, located in the upper front corner of my aluminum fuel cell. Just make sure you can reach the backside so you can tighten the nut on the fitting. I had to remove the filler cap and ring to be able to get my hand into the fuel cell.
I think I just drilled out the hole, and tried to keep all the chips out, but I run a filter before the pump, so it should catch anything I missed
Re: Drilling return lines in cell? #480428
09/26/09 11:37 PM
09/26/09 11:37 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
x2 i agree with SUPERSTOCKRACER,i used a step bit and it cut through with no effort and didn't damage the cell
Re: Drilling return lines in cell? #480429
09/27/09 07:50 AM
09/27/09 07:50 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
a step drill bit works like a charm. only needed one bit to do every size hole up to the 10AN to feed the pump.
Re: Drilling return lines in cell? [Re: jughed] #480430
09/27/09 08:03 AM
09/27/09 08:03 AM
once you go too big your done and no going back, i put duct tape under the area where you drill to catch the shavings and then took a plastic bag and opened it up inside the fuel cell to catch the remaining shavings, i also removed the foam and then vacuumed out any remaining shavings with a shop vac.
Re: Drilling return lines in cell? #480431
09/27/09 08:29 AM
09/27/09 08:29 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If your going to vacuum it out no need to do all the tape and bag stuff.
Re: Drilling return lines in cell? #480432
09/27/09 08:34 AM
09/27/09 08:34 AM
NC
440Jim Offline
440Jim  Offline
NC
One more vote for using a step drill, it works nicely. Never attempt with a regular drill bit, it will grab and tear.
I also removed the filler neck to get my hand in there. Shop vac and a cloth to make sure everything is clean.
Re: Drilling return lines in cell? [Re: 440Jim] #480433
09/27/09 08:39 AM
09/27/09 08:39 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Yup, step drill, rag under area, shop vac, remove filler neck and make sure you can reach where you are putting the hole.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Drilling return lines in cell? [Re: BBLM23] #480434
09/27/09 09:17 AM
09/27/09 09:17 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Here`s where my return and vent lines are located.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Drilling return lines in cell? [Re: chryco] #480435
09/27/09 10:46 AM
09/27/09 10:46 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i didnt have the right drill for mine,it was 11.0clock at night so i couldnt go get one so i just used an exacto knife,worked great.
