adjustment question. #480285
09/26/09 05:55 PM
09/26/09 05:55 PM
dark side of the moon
Dougsmopars Offline OP
I need to replace the break pedal rod from pedal to master. Manuel drum. I have a Mancini racing adjustable rod. What is the proper adjustment?
Re: adjustment question. [Re: Dougsmopars] #480286
09/26/09 08:31 PM
09/26/09 08:31 PM
extend it until the pedal height is where you want it but with it still contacting the plunger of the brake light switch. As you know the brake light switch itself has a slight range of adjustment so juggle the 2 so that it contacts the plunger keeping it depressed.
