Re: Whole floor or patch?
[Re: jjschm]
#480282
09/26/09 09:49 PM
09/26/09 09:49 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
I would do the whole floor, should be easy since it's a convertible, just remember to brace up the body before cutting so it doesn't fold in half.
It's time consuming but worth it if you're keeping the car long term, when I did the floor in my Dart I took out most of it using a 4" grinder with a cutoff wheel and used an air chisel to scrape the sheetmetal off the rails then it's just a matter of fitting the new floor, cleaning out and painting inside the rails, drilling about 1,000 holes in the new pan for plug welds and buzzing it in, it's also a good time to add subframe connectors if you don't already have them.
[Re: MoparJoe]
#480283
09/26/09 10:07 PM
09/26/09 10:07 PM
Posts: 4,872 connecticut
pnypwr
connecticut
convertibles are reinforced in the rockers id put in a door bar to do it but you dont have to get crazy for a floor pan replacement, as to the orig questions it depends on how bad the floor is, if the hole is the size of a quarter, or the size of a small farm animal...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
