55 Gal drum Alky users ?? for you #480180
09/26/09 02:49 PM
09/26/09 02:49 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
Once the seal is cracked on a drum, how long is the Alky good for? Do you guys have any special procedures for storing? Do you put the top oil in right away?
Thx in advance
Diego
Re: 55 Gal drum Alky users ?? for you [Re: Diego_Ted] #480181
09/26/09 06:54 PM
09/26/09 06:54 PM
usa
hot67cuda Offline
hot67cuda  Offline
usa
Hi keep it out of the sun preferably where ther is no temp change,or it will absorb moister.You can pour it in the cup of your floor jack and light it acouple of onces will be fine when it burns out look for any water left in the cup.That is the biggest problem with it.
Re: 55 Gal drum Alky users ?? for you [Re: hot67cuda] #480182
09/26/09 10:16 PM
09/26/09 10:16 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
yep, cool dry place is best. I keep mine in shed or my shop where it is often above 100*. I put the top lube in immediately. I have stored it for a year or so with no problems.
Re: 55 Gal drum Alky users ?? for you [Re: MegaDart] #480183
09/26/09 10:29 PM
09/26/09 10:29 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
From the methanex website
What is the shelf life/stability of methanol?
Without interference from or interaction with external contaminants, methanol will not deteriorate or decompose, thus the shelf life would be indefinite. Problems arise if the product is not protected from exposure to contamination, including exposure to the atmosphere.
http://www.methanex.com/products/faqs.html
I have had methanol in a barrel for 22 months and it tested the same as the day it was put in the drum.
Joe
Without Data, you’re just another guy with an opinion.
Re: 55 Gal drum Alky users ?? for you [Re: hot67cuda] #480184
09/26/09 11:37 PM
09/26/09 11:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That doesn't sound right to me, unless it has absorbed an enormous amount of water.
Re: 55 Gal drum Alky users ?? for you [Re: jcc] #480185
09/27/09 10:52 PM
09/27/09 10:52 PM
Diego-Town, CA
Diego-Town, CA
