Re: holley 750vac
[Re: swinger73]
#480083
09/26/09 11:59 AM
09/26/09 11:59 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
Tear it down and check it out.
The oil dripping is just soot that is now covered in the over rich mixture you are getting into the engine.
I bet you will see gas dripping out the venturi area while running if you look down the throat of the carb
I want my fair share
Re: holley 750vac
[Re: swinger73]
#480084
09/26/09 12:00 PM
09/26/09 12:00 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
you should tear it apart and check everything...
make sure the gasket under the power valve is installed correctly, sometimes they will slide to one side or the other and cause an internal fuel leak...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: holley 750vac
[Re: 70AARcuda]
#480085
09/26/09 12:02 PM
09/26/09 12:02 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Pull the needle/seat assemblies too and clean them up.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
