powersteering pulley #479926
09/26/09 04:40 AM
09/26/09 04:40 AM
Pa. bucks county
cuhemida Offline OP
cuhemida  Offline OP
Pa. bucks county
hey guys and girls
im building a 48 dodge coupe with a small block mopar... powersteering pump im iseing is off amid 80's GM nice and small and you can remove the tank and tuck it under the motor to hide it NOW THE PROBLEM dose anyone know or have a pulley that will if a 3/4 inch shaft on the pump mic. it at .750 and its a press fit no keyway
Tom
Re: powersteering pulley [Re: cuhemida] #479927
09/27/09 01:33 PM
09/27/09 01:33 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Can you use the current pulley, just press/pull to the right depth? Is it a serp pulley that's holding you up?
If it's a late GM metric (sounds like), are there applications that use a V belt pulley that will work?
They use those on rods all the time, there should be something that isn't Billet and Serp that will work.
Re: powersteering pulley [Re: RodStRace] #479928
09/27/09 06:49 PM
09/27/09 06:49 PM
Pa. bucks county
cuhemida Offline OP
cuhemida  Offline OP
Pa. bucks county
yes it has the serp. belt pulley and im going to be running V-belts so i am looking for a V-belt pulley that will fit that GM pump
Re: powersteering pulley [Re: cuhemida] #479929
09/27/09 08:57 PM
09/27/09 08:57 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: powersteering pulley [Re: OzHemi] #479930
09/28/09 11:38 AM
09/28/09 11:38 AM
Pa. bucks county
cuhemida Offline OP
cuhemida  Offline OP
Pa. bucks county
first thanks guy for helping yep that pulley from speenway will do the trick its nice to know there is always help from the guys in here
Tom
Re: powersteering pulley [Re: cuhemida] #479931
09/28/09 11:41 AM
09/28/09 11:41 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
