cracks on 308 heads #479650
09/25/09 08:28 PM
09/25/09 08:28 PM
hickory nc USA
skyhawk61 Offline OP
hickory nc USA
I picked up a set of 308 heads off a 360 down at the semi-local pick-a-part, haven't even got them de-greased yet. I've seen some traffic about crack problems with these heads. Where are they most likely to crack, and how critical is a crack that's not leaking water on a 308 head set up on a 360 street engine running 9:1 compression? I'm only out $40 for the pair. but it took me forever to find a set and I want to use them if possible. Thanks.
Re: cracks on 308 heads [Re: skyhawk61] #479651
09/25/09 09:01 PM
09/25/09 09:01 PM
Kentucky
E
ewolfe Offline
ewolfe  Offline
E
Kentucky
You got em cheap enough...drop them off at the machine shop for a check.
Re: cracks on 308 heads [Re: skyhawk61] #479652
09/25/09 09:15 PM
09/25/09 09:15 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Those cracks are almost certainly not the reason that truck went to the junk yard. If they are not into the water jacket, I would run them and not loose any sleep. Guesses are that lean fuel mixes on emissions engines made cylinder temps high enough for cracking. On a performance application, you'll probably have a richer mix and maybe a little lower cylinder temps. So on your engine they may not be as likely to crack.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: cracks on 308 heads [Re: GO_Fish] #479653
09/26/09 12:29 AM
09/26/09 12:29 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I left mine at the machine shop, they normally crack in-between the 2 valves on the end chambers, i'm sure mine were toast, the crack went down on each side about 3/4", also found cracks on the other head, so i junked them. On the 1 chamber that was really bad, showed signs of pitting on the valve & seat, so i'm sure coolant was getting in.
Most machine shops i've called are very familiar with the cracking issues on these heads & don't want to mess with them IF there cracked, your just rolling the dice whether they will leak or not, thats if the machinest doesn't want to jack with them & you just throw them on "AS IS".
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
