Let's talk OVERDRIVES ! #47904
11/12/07 08:06 PM
11/12/07 08:06 PM
Lost in Pooler, GA
Gumbydammit Offline OP
Lost in Pooler, GA
Hey all,
So I've been thinking about how I can have my cake and eat it too. . .
I have a 68 Dart going together with a healthy 440 ( 11.2:1 , .588 solid roller, stage 6 heads etc. ) and I'm thinking I'd like to have the ability to drive it here n there without listening to the motor scream all the way. I'm planning on a 3.91 or 4.10 gear and at least a 28" tall tire. I figure with the 727, a good converter, and some hook, the car should be able to rip off low 11s to high 10s, and I'd like to keep as much of the performance as possible
I know there is the Keisler 5-speed set up, but I don't think it will stand up to the occasional drag strip abuse I plan on putting to the car ( even with the TKO 600 ).
I've seen the Gear vendors unit and I think it may be a great option since I already have a built 727, but I'm concerned about how much power it'll rob and I hear they can be a pain in the but with the gear splitting (even though I really don't know how that works).
I've also seen the article in Mopar Muscle ( I think) where Keisler makes a kit to put a GM 4L80E behind a big block, but haven't seen a follow up as to how it held up so I'm a bit skeptical there.
So, what do you have? What are your opinions? ( Ho boy that's a loaded one ) Lets see some pics of your installs and hear what's good and bad.
I'm Gumby dammit!
Re: Let's talk OVERDRIVES ! [Re: Gumbydammit] #47905
11/12/07 08:09 PM
11/12/07 08:09 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard reports both ways about the GV units. Some say they've had no problems but I've also heard stories about them grenading.
You won't want to use gear splitting. Pretty much the way that works is you run in 1st with o/d off, then first with o/d on, then second and third in the same fashion. It's not worth the time it takes. You're better off just leaving the o/d turned off while you're going down the strip IMO.
Re: Let's talk OVERDRIVES ! [Re: DaytonaTurbo] #47906
11/12/07 08:15 PM
11/12/07 08:15 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
we run a GV unit. The '6' speed auto is a pain to try and do. We run it TF 1-2-3, GV-4. Thats it, we click it on whenever we hit the highway. No complaints as far as that goes. Not a huge fan of the 'auto-drive' setup, i rather control that myself.
Seems to be a good unit, doesn't lag or hesitate, doubt much power loss out of it.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Let's talk OVERDRIVES ! [Re: GoodysGotaCuda] #47907
11/12/07 08:25 PM
11/12/07 08:25 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
A500 here.Works like a 904 until you flip and the OD switch and then I also have a lock-up switch. 4.56's and 2400rpm at 60-65mph...Might loose a little power, but the od more than makes up for it. The A518 would be the bigger cousin you would want, or GV or a st1200 Lenco.
Re: Let's talk OVERDRIVES ! [Re: Dragula] #47908
11/12/07 09:07 PM
11/12/07 09:07 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
You can use an Utrabell on a Mopar SB auto. There is a nice thread in the truck section. I know a guy in TN that has the UB and had to get it machined to properly fit the starter.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Let's talk OVERDRIVES ! [Re: Dragula] #47909
11/12/07 09:35 PM
11/12/07 09:35 PM
Lost in Pooler, GA
Lost in Pooler, GA
Thanks! the GV seems like a good way to go. The st1200 would be the ultimate, but $$. I know one guy who has one in a Fairlane and beats the ever livin snot outta it! Isn't the 518 just like a 727? I don't know too much about them.
Anyone have any input on the Keisler 4L80E deal?
I'm Gumby dammit!
Re: Let's talk OVERDRIVES ! [Re: Gumbydammit] #47910
11/12/07 10:04 PM
11/12/07 10:04 PM
OK, I just heard somebody say A518 and an ultrabell. Why didn't I get that when I asked the same thing? Everybody and their brother was trying to steer me to a GV TF.
Re: Let's talk OVERDRIVES ! #47911
11/12/07 10:14 PM
11/12/07 10:14 PM
Rug_Trucker Offline
Rug_Trucker  Offline
We don't like you!
Well, lots of aluminum welding etc with that conversion.
Re: Let's talk OVERDRIVES ! [Re: Rug_Trucker] #47912
11/13/07 07:35 AM
11/13/07 07:35 AM
Dragula Offline
Dragula  Offline
The 518 IS a 727 with the same OD they put on the A500 which is a 904 with OD. Either can have an ultra bell put on them. The only problem with them is, you will have to fab your own cross memmber. The stock one will get hacked apart to use it. Mine has worked very well.
Re: Let's talk OVERDRIVES ! [Re: Rug_Trucker] #47913
11/13/07 08:21 AM
11/13/07 08:21 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
The Ultrabell bolts on--no welding, or am I missing something? This is the route I'm taking--A-518 and 512 stroker in a '69 Dart.
Re: Let's talk OVERDRIVES ! [Re: 375inStroke] #47914
11/13/07 09:16 AM
11/13/07 09:16 AM
Rug_Trucker Offline
Rug_Trucker  Offline
You're probably right. I know you need to cut the old bell off the OD tranny.
Re: Let's talk OVERDRIVES ! [Re: Gumbydammit] #47915
11/13/07 11:47 AM
11/13/07 11:47 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Hey all,
{SNIP}
the keisler auto isn't a 4L80, it's a 4L60E. I personally wouldn't trust one behind a healthy big block. if you don't mind cutting, and want an auto, I'd go with a 46RH (A518). you could sell your built 727 and converter probably for $500+, and you can get built 46RH's with a converter up to 2800-3k stall in the $2k-2300 range (or a little less than just the gear vendors cost. with the 46RH, you also get these advantages: .69 OD vs. .78, and a lockup clutch to eliminate converter slip on highway cruise (lower trans temps, more efficiency).
if cutting is an issue and you want a manual, your best bet IMHO would be to go with the passion OD gearset for an A833 4 speed. it's got a .8 OD, so it's about the same as a gear vendors.
2017 Grand Cherokee Overland
Re: Let's talk OVERDRIVES ! [Re: patrick] #47916
11/14/07 10:21 AM
11/14/07 10:21 AM
A Happy Place, A Happy Place, ...
57Plymouth Offline
57Plymouth  Offline
I have had a lot of experience with the GM 4L60E. It is a steaming pile of you know what. They keep blowing up behind stock 350's in trucks, what makes you think it will live behind a 440? Stay far far away from that pile.
Virtus Junxit Mors Non Separabit
Re: Let's talk OVERDRIVES ! [Re: 57Plymouth] #47917
11/14/07 10:27 AM
11/14/07 10:27 AM
Dragula Offline
Dragula  Offline
SMR trans is a good source for A500 and 518 parts, convertors, or the whole trans...
And the ultra bell requires your stock bell to be cut off and the UB bolts to the front pump on the trans. No welding. I will warn you though, the starter pocket needs to be trial fitted with the starter first. I had mine in and out of the car a gazzilion times to get it all to fit togather right.
Re: Let's talk OVERDRIVES ! [Re: Dragula] #47918
11/14/07 11:04 AM
11/14/07 11:04 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
My recollection is that the mopar OD automatics (518 in your case) have the OD section where the tailshaft is on your current 727. They require a lot of cutting and rebuilding of the torsion bar crossmember to fit. If you have test fit the trans, you should have a good idea of the area where the tailshaft fits.
Re: Let's talk OVERDRIVES ! [Re: 57Plymouth] #47919
07/27/08 07:19 PM
07/27/08 07:19 PM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
Maybe it's all the upgrades to make them live that drives the cost up to $5000.
Re: Let's talk OVERDRIVES ! [Re: 375inStroke] #47920
07/27/08 07:34 PM
07/27/08 07:34 PM
houston texas
gremlinsteve Offline
houston texas
ive gone through these same questions. i am steering towards the 727 i have and a GV unit behind that. its everything i want and need.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Let's talk OVERDRIVES ! [Re: 375inStroke] #47921
07/27/08 07:35 PM
07/27/08 07:35 PM
IMHO, I wouldn't use an overdrive unless you're planning on driving it a LOT on the freeway..........as in at least 3,000 highway miles per year......
Since you already have the 727, why not run a 3.55 gear with a PTC 3,800 converter? With a 3,800 converter, you won't need the bandaid 4.10 gears anyway.........The car will still haul the mail and be freeway friendly...... If you decide that you still don't like that, sell the complete 727 with converter and switch over then.....
The car below has a 10.9 to 1, pump gas, stock stroke, 440 with RPM heads and runs 10.70's @ 124 with 3.55's and a small roller cam....... The car runs and drives great on pump gas, but we raced it on race gas just to make sure we didn't have any detonation issues.......
Here's some more info about it........
