Re: valve cover gaskets *DELETED*
[Re: Big B]
#479089
09/25/09 09:39 AM
09/25/09 09:39 AM
Posts: 165 Madison WI
Sublime69
Madison WI
Post deleted by Sublime69
1969 Dodge Superbee - Original plain jane green 318 Coronet now Sub-Lime, 383 4 speed clone.
[Re: Big B]
#479091
09/25/09 10:38 AM
09/25/09 10:38 AM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
Mr Gasket Ultraseal with cast aluminum covers works for me. I tried Stock covers with the Moroso gaskets. I had oil all over the place. Changed back to the cast covers but reused the Ultraseals as they still looked perfect. When I need to replace the gaskets I suppose I will try the Morosos again but with the cast covers.
[Re: Big B]
#479094
09/25/09 11:22 AM
09/25/09 11:22 AM
No sticking and not one leak.. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Big B]
#479096
09/25/09 11:45 AM
09/25/09 11:45 AM
Posts: 257 madison, ohio
modified1090
madison, ohio
i use Fel-Pro Performance Z1611 - Fel-Pro Performance Fel-CoPrene Valve Cover Gaskets 15.95 at summit ![](/ubbthreads/images/graemlins/thumbs.gif) these dont leak, but you do have to re-torque them after they have been heated once then they are good to go... no leaks, reusable. i only have a set of cheaper stamped steel chrome valve covers these are the only ones i use. cork will crack and split if tightened too much and the rubber will split and deform if you try to reuse them.. i have found.
[Re: sc4400]
#479099
09/25/09 11:04 PM
09/25/09 11:04 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Is that for a set of 2 ? I am using the orange OEM style 4027092...aren't they the same? ![](/ubbthreads/images/graemlins/shruggy.gif) All I know is that there ain't no leaks...they don't split out like the Moroso Blues, and they are a lot more forgiving than corks. Even seal good on Eddy heads which from what I can see are a SOB to keep sealed.Ya don't have to keep ![](/ubbthreads/images/graemlins/wrench.gif) every 5 runs!
[Re: sc4400]
#479100
09/26/09 11:54 AM
09/26/09 11:54 AM
Posts: 325 Greenville, WI
Big B
Greenville, WI
P4120101 are orange rubber from ma MOPAR. They last for years. They work well on stiff valve covers. They are a well kept secret.
RIP
I ordered a set of Moroso blues. If those don't work I will try the MP orange.
[Re: Big B]
#479101
09/26/09 12:08 PM
09/26/09 12:08 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
No cork, no orange silicone[ they seem to swell and then bulge]. RBRE paper for both wedge and Hemi.
The little old lady from Pasadena is back!
[Re: markz528]
#479103
09/26/09 12:20 PM
09/26/09 12:20 PM
Posts: 21,086 Niles , Ohio
therocks
Niles , Ohio
Ultra Seals on the BBs and the SBs.None leak.Mine are off at least once a year to check adjustments on the solids.I get probally 2 to 3 years from them.Rocky
Chrysler Firepower
[Re: @#$%&*!]
#479105
09/26/09 10:14 PM
09/26/09 10:14 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
All I've ever used are cork gaskets. NEVER leaked. Here's how.
Clean the sealing surface of the valve cover. Make them SPOTLESS!!!
Use a good quality rtv, to "glue" the gasket to the valve cover. Then turn them over, on a workbench or something, and put some weight on the cover. Let it sit overnight.
Then, when you are ready to install the valve covers, smear a coating of grease on the head's sealing surface, or the gasket. Torque them down, and you're good to go.
As long as you have grease around the whole perimeter of the head's "lip", the gasket will never stick.
codfish
[Re: markz528]
#479106
09/26/09 10:36 PM
09/26/09 10:36 PM
Posts: 6,185 Bridgeport, WV
Michael
Bridgeport, WV
I got disgusted using valve cover gaskets so I o-ringed my covers......... Works awesome! ![](/ubbthreads/images/graemlins/thumbs.gif)
Now that's the way to do it!!! ![](/ubbthreads/images/graemlins/thumbs.gif)
