Re: Schubeck/SM Lifters?? [Re: 70VcodeCoronetRT] #479055
09/29/09 10:56 PM
09/29/09 10:56 PM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
If the spring pressure is right and you keep up on the valve lash, you will have no problems. We have used the solids in quite a few street engines. If you want hydraulics, you should go with the extra travel version, not the stocker lifters.
Let me know if you need any help.
Jeff
Precision Automotive Machine, INC
Canton, Ohio
Re: Schubeck/SM Lifters?? [Re: jdfpam] #479056
09/29/09 11:06 PM
09/29/09 11:06 PM
south louisiana
lowell66dart Offline
south louisiana
So could anyone chime in on the pros and cons of the ceramic verses the tool steel lifters. I have an R block that will have a solid in it for my next build and want to start collecting parts. This is a bracket engine (low,low 10's) and what I'm looking for is reliability.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Schubeck/SM Lifters?? [Re: lowell66dart] #479057
09/29/09 11:32 PM
09/29/09 11:32 PM
SoCal
Brian Hafliger Offline
SoCal
I know that if the ceramic lifter ever bounces on the lobe, the ceramic will shatter! We're doing a nice 440sb mopar right now with schubeck lifters and we're running 200lbs. on the seat and 480lbs. open and only revving it 6500rpm.
It would go more but my point is the tool steel will not shatter. I'd use a roller before I ever use these special FT lifters UNLESS there were rules OR it's going to see alot of street miles. Ofcourse then I'd probably use a hyd roller cam...LOL!
Brian Hafliger
Re: Schubeck/SM Lifters?? [Re: Brian Hafliger] #479058
09/29/09 11:53 PM
09/29/09 11:53 PM
On the south side of Nowhere
S/ST 3040 Offline OP
My Schubecks worked great. I never had to adjust the lash one time
all season but, since they fell apart, it just failed one of their selling
points...........re-using them almost indefinitely.
I'd love to use another set but, can't justify the cost a
second time. It's going to be plain old EDM solid or roller.
On second thought, I might stick these back in anyway.
