Lifter popping out of bore?
#478990
09/25/09 07:19 AM
09/25/09 07:19 AM
Posts: 2,165 Inver Grove Heights MN
74RR
Ok so I solved my oil pressure problem. One of my lifters popped out of it's bore and bent my pushrod. What causes this to happen,and how can I keep this from happening again? Thanks!
Re: Lifter popping out of bore?
[Re: 74RR]
#478992
09/25/09 07:54 AM
09/25/09 07:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You have it backwards..... the pushrod bent then the lifter came out.... pushrods bend for a few different reasons.... some were all ready stated
[Re: 74RR]
#478994
09/25/09 09:40 AM
09/25/09 09:40 AM
Posts: 864 St Paul MN
73swinger
St Paul MN
Did you have the heads checked before install, I've heard of some problems with tight valve guides. That could bend a push rod. Also what valve gear are you running?
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: 74RR]
#478996
09/25/09 10:42 AM
09/25/09 10:42 AM
73swinger
St Paul MN
Maybe double check rockers installed correct, I know small blocks have off sets. Also if the blosk or heads have been milled, push rods could be too long. Just throwing stuff out there. Sorry about your problem, I know this season is is winding down quickly.
Chris Schwartz
