Re: AIR CLEANER race with or without
[Re: Cab_Burge]
#478957
09/25/09 12:02 PM
09/25/09 12:02 PM
Posts: 3,746 Riverside, California
Lil Demon
The right air flter assembly will help the car go faster, even the air filter base without the rest of the filter can help in a car with no scoop or fresh air With a scoop on a Holley carb the filter can make a substantial gain in many cases, large diameter and a drop base to get the most hieght on the filter element helps, the K&N Extreme lids help also
Hey Cab - on the Demon - I don't have enough clearance between my carbs and scoop for an air cleaner. However, there is an in-scoop filter that mounts in the front ofthe scoop - not over the carbs. Does that type show a performance improvement as well?
[Re: Lil Demon]
#478958
09/25/09 12:45 PM
09/25/09 12:45 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I have no idea on that as I have not ran a car like yours or any other car with ascoop that needed a scoop type filter, sorry
[Re: Mr.Yuck]
#478960
09/25/09 05:58 PM
09/25/09 05:58 PM
Posts: 4,074 Mo.
racerx
Mo.
Do anyone run a drop base filter with n.o.s cyeniods mounted nextto the carbs? Thax...If so what type.
[Re: Lil Demon]
#478962
09/25/09 06:18 PM
09/25/09 06:18 PM
Quicktree
where did you get that type from? I would like to have one.
