Hot Coil? #478579
09/24/09 08:12 PM
09/24/09 08:12 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I know coils get hot, but how hot is too hot?
I was just running my starter to fill my carb with gas, and it got too hot to even hold. The car never got started. Is this normal?
Re: Hot Coil? [Re: 1fastrunner] #478580
09/24/09 08:40 PM
09/24/09 08:40 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Thats not normal. What coil are you running? How much voltage do you have at coil?
Re: Hot Coil? [Re: Dougsmopars] #478581
09/24/09 09:15 PM
09/24/09 09:15 PM
It's an FBO coil with the FBO ignition. How can I verify the voltage? Would it be hotter from just turning the starter than if the motor was running?
Thanks,
Re: Hot Coil? [Re: 1fastrunner] #478582
09/24/09 09:36 PM
09/24/09 09:36 PM
IA
landon1 Offline
landon1  Offline
IA
voltmeter + probe to + side of coil, - probe to ground
'71 Satellite Sebring 440
Re: Hot Coil? [Re: landon1] #478583
09/24/09 10:14 PM
09/24/09 10:14 PM
Dougsmopars Offline
Dougsmopars  Offline
You should only have around 11.5 to 13 volts at coil during start up. If your regulator is wasted you may be pumping over 15 volts into coil. That will over heat it very quickly.
Re: Hot Coil? [Re: Dougsmopars] #478584
09/25/09 02:59 AM
09/25/09 02:59 AM
Didn't FBO recently come out w a coil that takes a full 12V? As said put your VOM on it & see what you have & holler back.
Re: Hot Coil? [Re: RapidRobert] #478585
09/25/09 06:16 AM
09/25/09 06:16 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The current FBO coil can handle 8.5-11.0v. Don is working on a new coil and I got a pm from him yesterday saying that they are testing the new design.
Re: Hot Coil? [Re: YO7_A66] #478586
09/25/09 10:32 AM
09/25/09 10:32 AM
I'm getting 8.0 volts, and it's not as hot as last night. Like I said last night, I had the motor spinning for a total of 8 seconds probably over a dozen times with brakes to check and fix gas leaks in my fuel line while I got the carb full of gas. Will the coil get hotter if the motor is spinning like this without running?
Re: Hot Coil? [Re: 1fastrunner] #478587
09/25/09 10:51 AM
09/25/09 10:51 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
Yes because you send full battery voltage to the coil while cranking the engine
Kevin
Re: Hot Coil? [Re: C-Tech] #478588
09/25/09 11:03 AM
09/25/09 11:03 AM
So the coil should be good?
Re: Hot Coil? [Re: 1fastrunner] #478589
09/25/09 12:58 PM
09/25/09 12:58 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
If you've changed it recently double check the wiring.
Re: Hot Coil? [Re: pushbutton] #478590
09/25/09 03:51 PM
09/25/09 03:51 PM
Check the wiring for what?
